Solder joints on heat sinks matter?
This topic has been answered.
  • jm1234
    • Jan 2024
    • 61
    • Slovakia
    solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
    I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
  • Answer selected by jm1234 at 05-01-2024, 01:53 PM.
    stj
    • 31121
    if a heatsink has more than one mounting screw/pin/tab then you need to check if they are used - sometimes the heatsink is used to bridge 2 tracks across a board.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8275
      Usually if a transistor is mounted to a heat sink, I mount it on the heat sink first, then I solder the transistor to the board. Reasoning is that the solder joints are not being stressed. Some transistors will actually pop their lid off if you solder them first and then mount it.
        • 31121
          master hoarder
          • May 2008
          • 12175
          +1
          It depends on the PSU / board manufacturer, really.
          Some indeed use heatsinks to bridge/route ground to various places on the board, while others don't and the solder spots that hold down the heatsink(s) are isolated from the rest of the circuit. In any case, it's good to re-solder them if they are cracked. Otherwise, vibration can make the whole heatsink move more, eventually causing solder joint fractures to the parts attached to the heatsink... or in very severe cases, leads pulled out of parts.
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • abajor
            x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
            by abajor
            I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
            I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
            I found the schematic and diagram for the board here.
            https://www.badcaps.net/forum/troubl...e-devices/sche...
            07-20-2024, 04:46 PM
          • corrize
            Best way to solder LVDS connector for beginner (and qfn) ?
            by corrize
            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
            See the test :
            https://youtu.be/bNAzC-EvqHs?t=1767
            With hot air from bellow the board, that's...
            03-09-2023, 02:57 AM
          • Jeff'sTech
            Dell Latitude 7420 BIOS Unlock Gone Wrong
            by Jeff'sTech
            Hello everyone.
            I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
            11-08-2023, 03:30 PM
          • myth77
            UV solder mask - high temp resistent, recomendation?
            by myth77
            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
            Is there any solder mask...
            03-28-2022, 04:04 AM
