Polaroid 3211-TLXB Cap Issue
  • Ifixthings
    • Apr 2014
    • 20
    Hello all.
    My wife was watching tv and the screen went black. After unpluging the TV then plugging it back in the pic came back for a min then lines went through the picture then the screen was still visible but white. I opened the TV and spotted a bad filter cap in the PS, which I hope is my only problem. I also read the troubleshooting guide and see bad T-con board with white screen. Hopefully that's not my problem.
    Questions are can I get away with just replacing the 150uf 450v 105c Cap?
    Or do I need to replace others that are known to fail? All others APPEAR to be in good condition, BUT I also saw a post here saying HEC caps under the heatsink could be iffy.
    I tried to order a Panasonic cap from digikey and there are a TON of options/models. How do I know what series to buy ? Ripple current? Impedence?
    I attached a picture of the PS b/c maybe somebody will recognize it from another polaroid model and can chime in.
    thanks in advance
  • R_J
    • 9610
    Re: Polaroid 3211-TLXB Cap Issue
    That cap. is most likely o.k. it usually just the plastic that is bulged from heat. If that cap was bad chances are the tv would not work at all. I would look elsewere for the fault, possible main board or tcon, Im sure someone else has worked on these and can provide you with more information.
      I have seen that cap go bad on this model before. To confirm, you need to lift the cap up slightly and press on the plastic disc. If you can depress the disc the capacitor is probably OK; if not, you may have a problem with it.
      • Ifixthings
        • Apr 2014
        • 20
        I lifted the cap from the glue and pressed the bulged part it had very little flex. I plan on starting with the cap b/c swapping it seems like the easiest place to start.
        Can I throw a 150uf 450v 105c Cap from radioshack in there if they have one? Will any cap with this rating have the same impedance and ripple current specs?
        Edit: I have a cheapie Digital multimeter (craftsman), if anybody could point me in the direction of some testpoints/ usual readings.
          Don't use radioshack caps, they are no good... and they cost a fortune, for absolute rubbish.
          This ought to work: http://www.digikey.com/product-detai...378-ND/3134334
          $4.10 + $2.75 shipping.
          • Ifixthings
            • Apr 2014
            • 20
            Thank you Tom. Should I also replace EC17 and EC18 (the 2 smaller brown caps to the left of the heatsinks)? I saw a post where a user replaced these 3 caps and it fixed his TV. But these aren't bulged, burnt or leaking.
              You can if you like, for reliability only.
              http://www.digikey.com/product-detai...672-ND/1246001
              • Ifixthings
                • Apr 2014
                • 20
                I had those in my cart, ah the small victories lol. I just noticed that there are voltages written on the power board. The connector in red looks like it provides power to the logic board. The bottom right is AC in, and the white connector on left I think it's power to the panel (not sure) ? the one next to connector in red I dunno?
                Can I unhook all the connectors except AC in and check the voltages out of the red connector ? Will I burn something up by not providing a load? Is it better to leave everything hooked up and get a lead into the connector? Also the connector in red has 3 grounds and an aground. When taking readings can I use the chassis for ground?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  i would leave everything connected turn on the tv into the fault conditon then use the chassis as ground and push the red probe down the side of each wire to test the voltages test on dc volts see if they match whats printed on the board
                  • Ifixthings
                    • Apr 2014
                    • 20
                    I figured that's the best, if I got bad caps I just don't want to fry something else. Thanks for the info I will give this a try and report back.
                    • Ifixthings
                      • Apr 2014
                      • 20
                      Here's the update. Problem started as wife saying tv screen went black while front panel LED stayed lit. Unplugged TV for an hour plugged it back in it power up and the blue no signal screen looked perfect for a couple of secs then screen went white.
                      As of this morning the TV has been unplugged for a couple days and I have been trying to research parts, diagrams and possible problem. Thanks again to those that got me this far. I ordered the 2 10uf 450v caps and the big filtering cap from digi key. With the TV off and unplugged I tested F2 which was good and D10 which was also good- but I never unsoldered a leg. (these were issues in other polaroid TV threads)
                      Today I hooked up a blu-ray player and now the screen lights up completely white with sound, you can kind of see the images and menus do work.
                      I used the chassis as ground and took readings from the power out to main board (red connector in previous pic) here are the readings from left to right:
                      Board marking/ Actual reading
                      20V- 25.1vdc
                      12V- 12.1vdc
                      5VSB- 5vdc
                      STB- 4.5
                      These were taken while the movie was playing with fault present.
                      • Ifixthings
                        • Apr 2014
                        • 20
                        I been trying to find a schematic for this TV but have been unsucessful. I attached a pic of the main board and noticed some corrosion on the top right of the pic, I haven't had time to take apart the tv further was wondering if anybody knew what was in that area of corrosion? Also the connector where the camera flash is, is JP4 which I'm pretty sure goes to the TCon. Anybody know what pins to test to see if the main board isn't sending voltage? Since i'm not missing any voltages on my power supply (the 20 is reading high at 25v and I don't know tolerances for this) I think it's the TCon since everything else on the TV works, but I have no experience with TVs and would like to prove it without throwing parts at this.
                        Besides testing the power board for an AC ripple are there any other testpoints/checks I could perform with an O-Scope?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          before messing with it too much i would wait for the new capacitors to come and replace them first ive had a set with those two same caps gone causing simalar issues once replaced all was fine if youve never replaced capacitors before just make sure you fit the negative side as per how you remove it ive just had a set where some one recapped a board and two caps they replaced was around the wrong way!!!.
                          • Ifixthings
                            • Apr 2014
                            • 20
                            I will replace the caps, I just got them. It's crazy how much smaller the 105uf cap is! Fingers crossed this is the problem.
                            • Ifixthings
                              • Apr 2014
                              • 20
                              So I replaced EC17 EC18 and the bulging 150uF cap paying attention to polarity, and the TV still has the white screen, and 20V lead is still reading 25V. I tested the old caps with ESR meter and 150uf cap read 142uf, 10uf caps read 9.5 and 9.8 I believe . I don't know if I just didn't notice before but when the TV first turned on there were horizontal lines in the picture then just solid white, then when a movie plays you can see the picture just super washed out.
                              Any way for me to now see if the main board is sending power to the Tcon ? Expected voltages? I want to check as much out now before I completely disassemble the TV
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                theres a lead going from the main board to the tcon i would try to remove and refit it as it could be a bad connection i guess.
                                • Ifixthings
                                  • Apr 2014
                                  • 20
                                  The last pic I posted is the main board. Where the flash reflects is the connector JP4. Next to that connector are 2 posts. Are they for shorting a signal ? or test points? they are directly to the left of the connector in the pic.
                                  • Ifixthings
                                    • Apr 2014
                                    • 20
                                    been real busy so today is the first day in a long time I touched the TV...screen still shows faded polaroid screen at startup but turns solid white after- no picture....
                                    until I plugged it in again and pinned out connector coming from main board to TCon and now the pic is washed out but visible. Pinout while hooked up from top left to right, then bottom left to right
                                    4.6 4.6 0(black wire) 1.1 1.2 1.5 1.4 1.2 two wires far right are 0
                                    4.5 4.5 0(black) 1.5 1.4 1.3 1.3 1.5 two wires far right 0
                                    the wires that are at the far right of the connector on top are a gray wire and a black wire, on the bottom it's a blue wire and a black wire. my question is are the colored wires grounds or missing voltages ? because the main power board has only has 4 black ground wires going into the main board.
                                    are the rest of the voltages normal ? I'm trying to narrow down if it's the TCon
                                    EDIT: the pic is after I pinned out the connector....the best it has looked since I started
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Is this not an AS15 failure ?
                                      • Shinju
                                        • Mar 2014
                                        • 1239
                                        Looks like a Gamma issue, These Polaroid TV's have major power supply failures. Not constructed very well. I have one sitting that I replaced all the non working components on the board and it was working fine for a few hours and now the sucker after the Polaroid logo shuts the CCFL's off.
                                        Ugh..
                                        Good luck with this beast!
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
