ceramic capacitor question
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all I was wondering if I could use a 22j 6kv ceramic cap instead of a 3 5kv
    thanks in advance
  • Agent24
    I see dead caps
    • Oct 2007
    • 4973
    • New Zealand
    Re: ceramic capacitor question
    A higher voltage rating is OK but you should match the value unless you fully understand the circuit and know for certain changing it will not cause problems.
    -David VanHorn
    • wreksta
      • Aug 2013
      • 508
      • england
      the 5 3kv cap is a common fault on the 17ips10 psu from an alba
      • tw2005
        • Oct 2011
        • 6458
        thanks in advance
        We may need more info, what's it in, photos etc.
        So you want to use a 22pF 6000V instead of a 3 5kv.
        So what is that? A 3 pf 5000volt or are we talking same capcitance 22pf at 3500volts?
        • wreksta
          • Aug 2013
          • 508
          • england
          tis is he right cap from board originally
          5pf 3kv HIGH VOLTAGE CERAMIC CAPACITOR 5 PF 3000 VOLT
          • tw2005
            • Oct 2011
            • 6458
            I'm going with AGENT24. might be ok for fault finding but i'd put the correct value in there. Obviously higher voltage rating is not an issue.
            • wreksta
              • Aug 2013
              • 508
              • england
              care to explain the pf is it the substance inside viscosity or something like that
              • tw2005
                • Oct 2011
                • 6458
                picofarad / capacitance
                • tw2005
                  • Oct 2011
                  • 6458
                  http://en.wikipedia.org/wiki/Farad
                    That 5pF 3KV cap sounds like it is the ballast cap in the inverter output circuit for the CCFL. You should not go with higher value, but should go for higher voltage if it will still fit the footprint.
                    • chth96
                      Is it possible to test small ceramic disc capacitor with analogue meter?
                      by chth96
                      I read EBOOK of Testing Electronic Component and found that
                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                      Is it really possible to test small ceramic disc capacitor with analogue...
                      03-09-2024, 10:03 PM
                    • NuclearSpartan
                      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                      by NuclearSpartan
                      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                      I don't see any other visible damage anywhere else on the board....
                      11-14-2024, 02:32 PM
                    • rictechie
                      smd ceramic capacitor use in iphones
                      by rictechie
                      is there a brand of smd ceramic capacitor use in iphones? or they are generics
                      07-26-2024, 08:28 PM
                    • Prolog
                      RTX 3080 FE Identifying capacitor
                      by Prolog
                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                      I hope these photos make it clear which component I am referring to:
                      (yes, the soldering is a bit botched from removing the blown one, I know)
                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                      12-01-2024, 08:27 PM
                    • Sparklingx
                      SMD ceramic capacitor capacitance & voltage
                      by Sparklingx
                      what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                      09-12-2024, 01:04 AM
