ceramic capacitor question
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all I was wondering if I could use a 22j 6kv ceramic cap instead of a 3 5kv
    thanks in advance
  • Agent24
    I see dead caps
    • Oct 2007
    • 5036
    • New Zealand
    Re: ceramic capacitor question
    A higher voltage rating is OK but you should match the value unless you fully understand the circuit and know for certain changing it will not cause problems.
    -David VanHorn
    • wreksta
      • Aug 2013
      • 508
      • england
      the 5 3kv cap is a common fault on the 17ips10 psu from an alba
      • tw2005
        • Oct 2011
        • 6458
        thanks in advance
        We may need more info, what's it in, photos etc.
        So you want to use a 22pF 6000V instead of a 3 5kv.
        So what is that? A 3 pf 5000volt or are we talking same capcitance 22pf at 3500volts?
        • wreksta
          • Aug 2013
          • 508
          • england
          tis is he right cap from board originally
          5pf 3kv HIGH VOLTAGE CERAMIC CAPACITOR 5 PF 3000 VOLT
          • tw2005
            • Oct 2011
            • 6458
            I'm going with AGENT24. might be ok for fault finding but i'd put the correct value in there. Obviously higher voltage rating is not an issue.
            • wreksta
              • Aug 2013
              • 508
              • england
              care to explain the pf is it the substance inside viscosity or something like that
              • tw2005
                • Oct 2011
                • 6458
                picofarad / capacitance
                • tw2005
                  • Oct 2011
                  • 6458
                  http://en.wikipedia.org/wiki/Farad
                    That 5pF 3KV cap sounds like it is the ballast cap in the inverter output circuit for the CCFL. You should not go with higher value, but should go for higher voltage if it will still fit the footprint.
                    • MORETTIGIAN
                      by MORETTIGIAN
                      Title:
                      Description:
                      Procedure performed:
                      - Removed backplate
                      - Reapplied thermal compound
                      - Reassembled card
                      09-18-2025, 12:14 PM
                    • chth96
                      by chth96
                      03-09-2024, 10:03 PM
                    • NuclearSpartan
                      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                      by NuclearSpartan
                      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                      I don't see any other visible damage anywhere else on the board....
                      11-14-2024, 02:32 PM
                    • rictechie
                      smd ceramic capacitor use in iphones
                      by rictechie
                      is there a brand of smd ceramic capacitor use in iphones? or they are generics
                      07-26-2024, 08:28 PM
                    • Prolog
                      by Prolog
                      12-01-2024, 08:27 PM
