KDL-32L5000 Double Image Lower
  • dcapper
    • Dec 2013
    • 496
    I acquired this Sony tv and the lower half is jumping/double image/blurry. I pulled the whole panel apart. When I put pressure on the tabs, my picture never changes. But when I freeze spray the left side in the middle the picture clears up. Although I have a horizontal line across the middle of the tv. Is it same to assume my panel is bad? I attached pics.
  • dcapper
    • Dec 2013
    • 496
    Re: KDL-32L5000 Double Image Lower
    Anyone have any ideas on the one? The 2nd pic shows where I spray to clean up the picture.
    • geminidpr
      • Dec 2011
      • 41
      It sounds like a tab bond issue but usually if you put pressure on it, it should clear up the screen. The freeze spray remedy is very interesting. Too bad its only temporary.
        You probably have an IC-level tab fault. I've had ones where you have to apply direct pressure to the IC on the tab. I've had no luck finding a permanent fix for one like that.
        • dcapper
          • Dec 2013
          • 496
          I spray it right in the middle on the right side and the pic clears up. I press on the bond tabs and it doesn't fix the picture. If you notice there is a horizontal thin line right across the screen in the middle. Don't know what would cause that. Bad panel or bad panel with faulty tcon.
          Here's a video on the same thing.
          http://www.youtube.com/watch?v=Qj51BkS9d-0&feature
            I agree with TOM that it is the TFT driver IC on flex PCB.
            • dcapper
              • Dec 2013
              • 496
              Parts tv it is then.
              • howardc64
                TCL 49S405 double image
                by howardc64
                LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                06-23-2025, 03:20 PM
              • Cornito
                Samsung UE55RU8000 reboot and then double image after heating up
                by Cornito
                Hello team,
                I'm back with another tv and another problem.
                I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                First, reboot issue, I use tape Method to find out the right side that cases the issue.
                Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                Then double image reduce in height and move to the top.
                The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                When I...
                03-31-2024, 01:37 PM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
              • piershs
                Toshiba plasma 50WP16 wierd double image fault
                by piershs
                My 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
                Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):
                • 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
                • 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
                08-01-2020, 01:07 PM
                HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                09-06-2024, 10:56 AM
