RCA RLED4778A No Backlight no Pic No Response
  • mmartell
    • Oct 2013
    • 3189
    Standby light lit and set responds to power up by changing red standby light to blue. Other than that no indication of any life. Will not go back into standby and power must be cycled at the mains to go back into standby.
    All voltages present at PS after power up.
    I'm thinking main/driver board/tcon in that order.
    This is an LG panel and probably other internals. One and a half years old.
    Need advice on how to narrow this down as I'm not familiar with failure modes on this set and there are no schematics/manuals that I can find.
    Pics are of PS, main, driver board. Tcon buried atm.
  • mmartell
    • Oct 2013
    • 3189
    Re: RCA RLED4778A No Backlight no Pic No Response
    Is there any common or generic fault with LG led tvs that would cause this symptom ?
    And any idea on how to test the backlights on this ?
    • mmartell
      • Oct 2013
      • 3189
      By the way the fault was degenerative - it got worse over time to the point it will no longer power on and work normally.
      As an aside the main board in about the size of a pc video card !
      Could use some troubleshooting tips here...
      • paulstef
        • Dec 2013
        • 724
        Sounds more like resistors or capacitors. Any way you could get it working by heating or cooling the boards?
        • mmartell
          • Oct 2013
          • 3189
          I've tried heating all the boards (except the tcon) to no avail. Cooling seems doubtful to me as a dead set is pretty cool to begin with lol.
          Perhaps I should have a look at the tcon. I've been avoiding tearing off the shield because that means taking off the stand as well. Can a faulty tcon cause these symptoms ??
            Not from my experience.
            • mmartell
              • Oct 2013
              • 3189
              There is a three pin jumper located on the main board just beneath the horizontal power connector at the top right of pic four above. The jumper can be moved over to short the top two pins instead of the bottom two pins. Any idea what that's for and how to use it ? Wondering if it's some sort of "reset" - not that it makes for any real solution.
              • paulstef
                • Dec 2013
                • 724
                Depending on where in the circuit a temperature sensitive component is located cooling it can have an effect, yes. 20 deg C is cool. -40 C is cooler. Just a thought.
                • mmartell
                  • Oct 2013
                  • 3189
                  I got ya. Just more of a believer of the "heat expansion for intermittent contact" in this situation as the set doesn't work for a period and then shut down.
                  Well, that and I'm out of canned air lol.
                  • paulstef
                    • Dec 2013
                    • 724
                    Not only this. There are many failure modes for all kinds of components. I would always go in both temperature directions. From experience. Easiest thing to do before serious troubleshooting.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Will get some dust spray tomorrow and giver er a try.
                      • paulstef
                        • Dec 2013
                        • 724
                        I'm sure you know that inverting the dust spray can it gets really cold. Just saying.
                        Otherwise, cooling spray.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Yes that's why I'm getting Dust Spray. Will report back tomorrow.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Hosed down the main board with cold air - no change.
                            I suspect component failure on the main board. Since it's quite small with few components I'm going to go over it with my meter and see if anything presents.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Verified I have good standby voltage and good PSON when power button pressed. After that the red standby led turns to blue all voltages are present except there is NO BLON from Main and set becomes frozen. It's possible the main IC is toast.
                              Generally does the main board interact with the tcon before issuing BLON ? I ask because that's the only board I haven't looked at yet.
                              I can find no shorts on the Main board. All five regulators measure good.
                              Am going to recap it as I can't find the board anywhere. Maybe there is ripple even though the esr looks good ?
                                "Generally does the main board interact with the tcon before issuing BLON ?" Most are not, some may use T-CON error to shut down the backlights and the other circuit at the same time. See if you get voltage at the T-CON since the processor also send the panel on signal to turn on the MOSFET on the main board that supplies the voltage to the T-CON fuse. It sure sounds like you have main board problem. You can also cut the BL_ON wire to allow you to force on the backlights circuit, once you have backlights and nothing else on the main board is bad you should see picture on the screen.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Well found NO VOLTAGE at the tcon fuse. In conjuntion with what you said above and the fact the set appears frozen after PSON command I would say the processor is not running or related components have failed or are without voltage.
                                  I will check for voltages at the flash, ram, eeprom and processor. Beyond that I'm not sure how to verify their operation.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Capacitor E6 (100uf 16v) would not read in circuit with my esr meter. Read fine after taking it out. The cap is fed by a 1.8v regulator. It looks like it *may* feed the processor.
                                    The circuit that it's in measures about 65ohm to ground. Is that possible or does it indicate a problem (a leak to ground) and where would I look for it ?
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      Some pics.. I would replace it but can't find it anywhere.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Need some help troubleshooting this...
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • BoardHoarder
                                          XBR-65X850D Backlight/Power On Help
                                          by BoardHoarder
                                          Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                                          02-09-2024, 11:00 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • BakaMonogatari
                                          LG 65UJ6300 no backlight unless TCON disconnected.
                                          by BakaMonogatari
                                          Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                          TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                          11-04-2021, 12:36 PM
                                        • MoreMagnets
                                          Sony KD49X8000H - Sound, backlight, no picture
                                          by MoreMagnets
                                          Hello all!
                                          This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                                          Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                                          10-23-2022, 09:31 PM
