RCA RLED4778A No Backlight no Pic No Response
  • Mayn
    • Nov 2016
    • 54
    Re: RCA RLED4778A No Backlight no Pic No Response
    Same tv, same symptoms. 400deg for 10 mins in the oven for the main board and it works again
    • fixer-68
      • Apr 2020
      • canada
      #42
      Same tv, same symptoms. 350deg for 10 mins in the oven for the main board and it works again. How strange is that, does anyone have an explanation for why this works, and how long has this fix lasted? Also is this the only set that this method has worked on?
      • nomoresonys
        • 12276
        • U.S.
        #43
        Bga on the mainboard overheats, try rigging up a fan solution to keep it cool, it may last a long time, without the extra cooling of a fan it might only last a day a week or a few months more than likely. I've seen where a second heating after tv quits working again may work but many times the second heating does not work.
        • KevinK
          • May 2014
          I expect it re-flows the solder. The TV I fixed was my brother's, and he gave it to his girlfriend. I've asked him about it at times and as far as I know it's still working, after 5 years.
          • nomoresonys
            • 12276
            • U.S.
            #45
            Good to hear, most don't fair nearly as well.
            • diif
              • Feb 2014
              • 6978
              • England
              #46
              There's no reason to think if the BGA has only failed after 10 years then it should last another 10, if the reflow is done well. If it's not cost effective to reball then I reflow and I haven't had one back yet.
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • BoardHoarder
                XBR-65X850D Backlight/Power On Help
                by BoardHoarder
                Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                02-09-2024, 11:00 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • BakaMonogatari
                LG 65UJ6300 no backlight unless TCON disconnected.
                by BakaMonogatari
                Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                11-04-2021, 12:36 PM
