RCA RLED4778A No Backlight no Pic No Response
  • mmartell
    • Oct 2013
    • 3189
    Re: RCA RLED4778A No Backlight no Pic No Response
    Should there be about 65ohms between any rails ? I'm getting that between the 1.8v supply and ground.
      that would generally indicate a shorted CPU to me.
      • mmartell
        • Oct 2013
        • 3189
        I don't see a separate micom to control standby functions. Do cheaper sets like this use the main processor for that ?
        • mmartell
          • Oct 2013
          • 3189
          I ask because standby seems to work. When power button is pushed light turns blue and set is unresponsive until power plug is removed and reinserted.
          Would be a strange fault for the processor to work and then freeze up, no ?
            Yes, this uses one processor to do both, and it is odd. It is also plausible the regulator is bad.
            • mmartell
              • Oct 2013
              • 3189
              I tore the heatsink off it. It is a Renesas RA... uses 1.2, 1.8 and 3.3v supplies. The question is are the lower voltages switched on at power up ? Will check that when I can.
              I remember the voltages at the regulators testing good.
                1.2V is the core, 3.3V is IO.
                1.8V might be for analog interface. It's odd for it to use both 1.2V & 1.8V.
                • mmartell
                  • Oct 2013
                  • 3189
                  That info is according to their website. Can't remember the full part number atm.
                  Now that I think about it I believe the 1.8v and the 1.2v lines share the same low resistance to ground. Is there anything in common between the two other than the processor ?
                    Capacitors, and sometimes 1.8V will be used by memory or other ICs on the board.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Crap. A shorted mlcc is nearly impossible to find isn't it ?
                      • mmartell
                        • Oct 2013
                        • 3189
                        Ordered a main board. Hoping for compatibility as it's not an exact match as per sticker data.
                        Will post back...
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          #32
                          I'm sure that will fix it,as it sounds very strongly like a bad voltage regulator to me on the main board...
                          Vizi......oh....oh..... are notorious for the exact same problem.....0.12 volt out of spec on one regulator and nothing else then powering on,non responsive after start up....
                          Proud owner of dozens of broken TV's and many,many,many boards.
                          Our website and passion:http://hollenhundshepherds.com/
                          • mmartell
                            • Oct 2013
                            • 3189
                            This board was suffering a short, likely in the main processor.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Replacement main board fixed the tv. I measured the five regs on the good board vs the bad board and they are identical. Well, one reg was 0.02v lower can't see that causing a problem...
                              This working board also showed the same low(ish) resistance to ground from the reg outputs so now I don't really know what to think as to what the actual failure was.
                              • KevinK
                                • May 2014
                                I have the same TV on my bench with the same problem - it initializes occasionally when power is applied, will turn "on" according to the power LED, but won't turn off.
                                I'm new to flat screen TV repair but not to electronics. The supply voltages are present and within spec when the machine is turned on but there's no other sign of activity.
                                mmartell, can you tell me where you found your board, and if it's an RCA board? If it's a Sceptre or some other board, does that make any difference beyond the startup screen?
                                I did see the other thread about the Sceptre TV.
                                Thanks,
                                Kevin
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I found the board on ebay and it was an RCA though I was prepared to use another brand hoping that the only difference would be the splash screen.
                                  These are rare boards. Search for the "12035..." number (going from memory). Then match the sticker on the back as best you can.
                                  • KevinK
                                    • May 2014
                                    Update:
                                    I froze the board for a while (in the freezer) which didn't help so I baked it at 300ºF for 10 minutes. That was 2 days ago and it's worked fine ever since!
                                    Kevin
                                    • ferous
                                      • Nov 2014
                                      • canada
                                      #38
                                      Originally posted by mmartell
                                      Standby light lit and set responds to power up by changing red standby light to blue. Other than that no indication of any life. Will not go back into standby and power must be cycled at the mains to go back into standby.
                                      All voltages present at PS after power up.
                                      I'm thinking main/driver board/tcon in that order.
                                      This is an LG panel and probably other internals. One and a half years old.
                                      Need advice on how to narrow this down as I'm not familiar with failure modes on this set and there are no schematics/manuals that I can find.
                                      Pics are of PS, main, driver board. Tcon buried atm.
                                      Hello I'm Dominic
                                      Looks like we all have the same problem, searched with all my contacts and still no luck, any luck on your end?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Read the previous 3 or 4 posts to find out two different resolutions.
                                        • Jeep16
                                          • Apr 2016
                                          Originally posted by KevinK
                                          Update:
                                          Kevin
                                          I found that freezing the processor caused the display to come on. I tried Kevin's suggestion of baking the board at 300F, but two caps just popped and now I am looking for a new board (I might try replacing the caps if the board is not available.) Maybe should have tried 250F?
                                          • howardc64
                                            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                            by howardc64
                                            Problem
                                            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                            Model & Board Pics
                                            Conflicting Spec
                                            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                            https://www.shopjimmy.com/vizio-gj-2k1...
                                            10-10-2024, 01:16 PM
                                          • BoardHoarder
                                            XBR-65X850D Backlight/Power On Help
                                            by BoardHoarder
                                            Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                                            02-09-2024, 11:00 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • BakaMonogatari
                                            LG 65UJ6300 no backlight unless TCON disconnected.
                                            by BakaMonogatari
                                            Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
                                            TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
                                            11-04-2021, 12:36 PM
                                          • MoreMagnets
                                            Sony KD49X8000H - Sound, backlight, no picture
                                            by MoreMagnets
                                            Hello all!
                                            This post will mostly just act as documentation for my undertaken troubleshooting steps for this TV. Advice will also be appreciated for things to try next
                                            Picked up the TV in thread title from a retail returns auction, symptoms were as described. I started my troubleshooting attempts by shorting the 19V PSU rail to the 3v rail with my multimeter... Doh. Big spark, dead PSU, TV not turning on anymore. Picked up a new mainboard and PSU locally from someone here in Sydney, wasn't sure if my butterfingers had killed both and was a big drive to pick them...
                                            10-23-2022, 09:31 PM
