Vizio VW26LHDTV10F, No Sound, Backlight and Standby Light
  • Grannyrogers
    • Mar 2014
    • 14
    • United states
    No sound, No backlight, No standby light..
    When the power button is pressed, nothing happens.
    Tests that I have done:
    Power Supply:
    Legs of large capacitor registers 402v consistently
    With logic and inverter board unplugged, I registered 5v only on connector pins labeled "5v"
    With logic and Inverter plugged in, I registered 24.5v to the inverter and 14.45v and 5v to the logic board.
    Logic Board
    regulators:
    u3
    AC 7A1L
    17-33L
    PIN1=0
    PIN2=.78
    PIN3=1.68
    U5
    AC 7A1L
    17-33L
    PIN1=0
    PIN2=.82
    PIN3=1.69
    U6
    AZ1084S
    -ADJE1
    713J71
    PIN1=.50
    PIN2=.81
    PIN3=1.69
    U8
    A1084S
    -ADJE1
    713J71
    PIN1=.42
    PIN2=.80
    PIN3=1.69
    U9
    AC 713L
    1117L
    PIN1=0
    PIN2=.09
    PIN3=.81
    U10
    AC 7A1L
    17-33L
    PIN1=0
    PIN2=3.30
    PIN3=5.03
    U11
    AC713L
    1117L
    PIN1=.01
    PIN2=.04
    PIN3=.81
    U28
    J201
    78M12
    PIN1=14.45
    PIN2=.01
    PIN3=11.93
    U31
    UTC
    78D05AL
    05UKCG
    PIN1=11.93
    PIN2=.01
    PIN3=4.99
    U33
    AC 7A1L
    17-33L
    PIN1=0
    PIN2=.72
    PIN3=1.69
    Any Help is appreciated. Thanks
  • Grannyrogers
    • Mar 2014
    • 14
    • United states
    Re: Vizio VW26LHDTV10F, No Sound, Backlight and Standby Light
    Here are some Pictures:
      You need to retest the input voltage to pin 3 of U3, U5, U6, U8, U9, U11, U33: they are way too low.
      • Grannyrogers
        • Mar 2014
        • 14
        • United states
        Thanks for replying so quick Budm.
        I rechecked all of them with the MM black wire to chassis, and I am still getting the same values.
        I forgot to mention that I replaced two bulging capacitors on the powersupply. they were 2200 uf 10v each.
        Do you think the main board is no good?
          The problem is on the main board right now due to very low DC input voltages feeding those regulators, need to find out why you are getting only 1.69V,and 0.81V to those input pins.
          One things that does not make sense is that you are able to get the 24V isnce with that low voltages on the main board, it will not function to send out the PS_ON signal to turn on the 24V power supply.
          • Grannyrogers
            • Mar 2014
            • 14
            • United states
            Is there anything else I can test?
            • Grannyrogers
              • Mar 2014
              • 14
              • United states
              I did some reading, and it seems the 24v is active because the PS-ON signal coming from the mainboard is low. Normally, when the TV on/off swtch is pressed, the voltage to the PS_ON drops which tells the power supplies to initiate the 24v
                Hmm, most Vizio uses active high, but may be this one is active low. What is voltage at PS_ON when TV is in standby mode? The main key right now is to find out why we are having really low voltage feeding the regulator ICs. You may have trace out to see if all those input pins are tied together on the one with 1.69VDC reading, then trace out where it goes after that.
                • Grannyrogers
                  • Mar 2014
                  • 14
                  • United states
                  I cant tell if TV is in standby mode or not because the standby light is off. However, the voltage at PS_ON is 1.205v.
                    It should toggle when the power switch is turned on and off, if it does not change state, then that control line is also not working.
                    • Grannyrogers
                      • Mar 2014
                      • 14
                      • United states
                      Nothing happens when I toggle the on and off switch. The voltage does not fluctuate, so that control line appears to be dead as you stated. Mystery deepens.
                      I get .02v at on/off and .80 at IVT_DIM
                        Nothing is going to work right until we get the correct voltages from those regulators.
                        • Grannyrogers
                          • Mar 2014
                          • 14
                          • United states
                          I tested this 8 legged thing and it has the correct 5 volts on one side and the 1.69v that we see going to the regulators on the other side. Oh and that 1.69v is now 1.65v. It is decreasing. I am going to upload a pic of it. I think it is called variable capitance diode.
                          Could this be problem?
                          • Grannyrogers
                            • Mar 2014
                            • 14
                            • United states
                            Hey budm,
                            So I ordered a mainboard off ebay for $38 and I just installed it; however, when I press the power button all I got was the standby light and backlight. I tested the voltages and I got normal voltages. 5.03v, 15.06v and 24v. However, shortly after, I smelt something burning and when I tried turning tv off, nothing would happen. I unpplugged the tv then replugged it back into the outlet and now it is as before, just a black screen with no standby light. I retested the voltages and they are, once again, just as on the old board. All low voltages going to several regulators except one. Do you think a bad Tcon board could cause this or is it a bad power supply?
                            • Grannyrogers
                              • Mar 2014
                              • 14
                              • United states
                              Oh. On the new board, an 8 prong mosfet is burnt. It is located beside the connector from the PS. The volts coming from it matches the volts going to the regulators.
                                Can we see a picture of this burnt MOSFET? The seller probably didn't test the board, they rarely do.
                                • Grannyrogers
                                  • Mar 2014
                                  • 14
                                  • United states
                                  Hi tomm66, thanks for assisting.
                                  The board I bought was good when I got it. The original one had no standby light, no sound, no backlight, but when I installed the new one, I saw standby light and I got a white backlight then I smelt something burning.
                                  Upon closer inspection of the original board i notice that the same MOSFET was burnt as well. I have uploaded pictures of both.
                                  What do you think is causing the mosfet to burn up?
                                    It looks like it is being used as a switch.
                                    • shelby5041
                                      vizio d40f-j09 no pic no sound standby always clear
                                      by shelby5041
                                      hi
                                      anybody have experience with this model tv
                                      07-19-2025, 06:58 AM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
                                    • ChaosLegionnaire
                                      by ChaosLegionnaire
                                      09-13-2022, 09:02 AM
                                    • B0r1s
                                      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                      by B0r1s
                                      PSU - BN44-00878A
                                      Symptoms:
                                      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                      A weak clicking sound was coming from the transformer.
                                      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                      Progress:
                                      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                      01-17-2023, 04:58 PM
                                    • rebelkustoms
                                      VIZIO D60-F3 Wont Power ON, No Standby, No Picture, No Sound
                                      by rebelkustoms
                                      Hi all, got a new set to look at. This one is a Vizio D60-F3 it has no standby light, wont power on and has no pi or sound. I have checked continuity in the fuse. I checked the pinouts to the motherboard several times and I am getting no voltage on any of the pins. Guy who gave it to me told me it was turning on then going off and then it stopped coming on. There are pics of the model and powerboard. Thanks...
                                      10-29-2020, 12:23 PM
