Philips Tv PSU Cap exploded!! Help!
  • Gbucks7
    • Mar 2014
    • 35
    • Ireland
    Hey Madcappers, Greg here, having an issue with my TV and told this was the place to come so here goes...
    Item: Philips 42"LCD TV- 3 years old
    Model: 42PFL5405H/05
    PSU: LG
    Power supply: 230v {Ireland}
    Problem:
    Tv was on standby, pressed the power button on the remote- loud bang, some smoke and a few sparks. Then nothing- no life in the tv. The 3a fuse in the plug also blew. My PS4, SKY box and router that were plugged into the same adapter block were all unaffected.
    I removed the back cover and the PSU {im an electrician so safety measures were always in play} and discovered that a disc capacitor had exploded. Unfortunately due to the damage sustained the specs are somewhat illegible. The cap has been removed and cleaned a bit so im pretty sure it reads 1kv and the 'k' value begins with 10, other than that ive no idea what the specs are.
    So its time for the electrician to sit down and stay quiet and let the electronic gurus tell me what's what....
    Some Questions:
    Why did this cap blow, is there a history of them being faulty or is it a bigger problem?
    Can the cap simply be replaced? If so will the TV be safe i.e. fire hazard?
    Can anyone correctly identify the cap and specs so i can order it?
    I've attached some pics so hopefully they help, cap location on the board is c502, any help would be great
    Cheers guys
    Greg
  • japlytic
    • Oct 2005
    • 2086
    Re: Philips Tv PSU Cap exploded!! Help!
    Welcome, Gbucks7!
    This capacitor which is blown is a high voltage ceramic unit, but it is difficult if not impossible to determine its value without a schematic.
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
    • janos6662000
      Philips 47PFS7509/12 LCD TV problem
      by janos6662000
      Hi
      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
      When i applied cable signal to check image, i had normal picture, but TV was restarting.
      I downloaded original firmware and applied the update, but the problem remained.
      From a colleague i received a "factory package software" which is a lot bigger.
      I made another firmware update, but still did not solve the problem.
      Somewhere on the way the error got worse, because at the moment the...
      08-12-2025, 12:54 PM
    • aidanmo
      Philips 43PUS7506/12 - Loud blown out sound
      by aidanmo
      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
      I thought maybe the speakers got damaged, so I replaced them - no dice.
      • Using the internal speakers, it always happens.
      • Using the headphone jack, it never happens.
      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
      02-28-2025, 03:13 PM
