pn50b650s1f
  • bodaciuos
    • May 2011
    • 43
    pn50b650s1f
    having voltage issues on my samsung plasma pn50b650s1f. at first i had no sound or picture. after a couple of replacement part. i at least have audio know. so getting to my issue is that when i plug it in audio boots up fine but with no pic. i check all the reading on power supply voltage is fine . but the no. 1 PS pn pin to control board goes from 3volt to 125 from stby to on . do i have a short maybe. has anyone ever have this issue..
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: pn50b650s1f
    Check fuses on ysus first, xsus second, probably going to be buffer failure that took out your ysus. what parts did you replace?
    Liberating magic smoke one part at a time
    • bodaciuos
      • May 2011
      • 43
      Re: pn50b650s1f
      y s is good get vscan voltage -200 it . replaced the control board and main board.and the power supply
      • bodaciuos
        • May 2011
        • 43
        Re: pn50b650s1f
        i do have a buffer board and y sustain i was afraid to install it .ill try to see if that the problem. i didn't think i was.
        • bodaciuos
          • May 2011
          • 43
          Re: pn50b650s1f
          ok at least know i get a faint glow on the panel.. but not up completely. im still getting 126 volt on the ps on in thou. getting closer . thank for your input celeb.bro..lol
          • bodaciuos
            • May 2011
            • 43
            Re: pn50b650s1f
            any one know how to check ir board? to eliminate the probability. or check ardress board. i here they have a fuse on them but i dont see any..
            • Caleb
              Smokin IC's
              • Feb 2013
              • 645
              Re: pn50b650s1f
              I doubt it is the ir board, What is the panel number on your tv, i can see the sticker in the picture with the xsus but cant read the fine print- I came up empty on the model# for a service manual. If your panel is primed (glows) you could still have a main board issue. you can try jumpering pins 3 and 4 on the control board with lvds unplugged and see if you get test patterns on the screen.
              • bodaciuos
                • May 2011
                • 43
                Re: pn50b650s1f
                thanks,, if u can find service manual. can u get it to me ? that will be great. sorry we may be in different time zone but in i WA state.
                • bodaciuos
                  • May 2011
                  • 43
                  Re: pn50b650s1f
                  so i found a bad fuse on the e buffer board blown at least i think that what its called ,bottom of the tv. its on f2500. it says f8r on it. any one know where i could find this fuse? or a compatible one. also i remove the plug and im hoping there in the right position. if any one can verify if the plug are on correct. thatll be great. if u notice the blue dot that will be my reference.
                  • bodaciuos
                    • May 2011
                    • 43
                    Re: pn50b650s1f
                    tried to get a test pattern, no good. but by looked at the screen carefully. it has a 5 inch lighter glow on each side than the middle of the screen. if thats any help or indication of a specific problem.
                      Re: pn50b650s1f
                      The connections are OK compared to another model I did recently.
                      It's important that you DO NOT unplug/plug in that connector while the unit is running.
                      Not only will the fuse often blow it can also damage the plasma panel drivers which are non replaceable!
                      Also, you absolutely MUST have the heatsink bolted on them while running it.
                      • Caleb
                        Smokin IC's
                        • Feb 2013
                        • 645
                        Re: pn50b650s1f
                        this is the closest thing to your tv sm I could find, attaching the quick start sheet as well for a similar model. Im not sure what the rating on that fuse is, however you should test the outbound side of that fuse against ground to see if you have a short present before replacing.
                        • bodaciuos
                          • May 2011
                          • 43
                          Re: pn50b650s1f
                          so will this buffer board make my ps on pin to go up to 126 volt? ps on stby is 3volt which is good but when i turn on the set, it shoots up to 126 volt.
                          • Caleb
                            Smokin IC's
                            • Feb 2013
                            • 645
                            Re: pn50b650s1f
                            are you saying your getting 126 volts on the standby circuit? 126v would be ok in parts of the power supply but certainly not on the standby circuit. You should have about 120 volts on the ac side of the bridge rectifier, if the pfc isnt working you might find that on the filter cap although it should be up in the 170v range before the supply turns on then bump up to about 350 volts or more.
                            It would probably be best if you note the supply voltages that are marked on your tv and compare them to the readings you have on each connector. Also make sure you are using the right setting on your multimeter (with a good battery) and the proper ground point for the section you are testing. You may be getting erroneous readings otherwise.
                            • bodaciuos
                              • May 2011
                              • 43
                              Re: pn50b650s1f
                              yes you are correct. this is my voltages . cn108 pin 1 of 24 pins. three volt stby. when i turn on the set, it goes to 123-126 vlts. getting 5.3 volt on stby pin 5,and stays there when i turn the unit on . i believe pin 5 stby pin is supose to drop. voltage on y buffer are correct and xsus r correct ..
                              • Caleb
                                Smokin IC's
                                • Feb 2013
                                • 645
                                Re: pn50b650s1f
                                I would try to isolate that 126v, see if it is coming from the power board or coming off sc or ss. If you have two circuits tied together it could be bad for the components on the low voltage side of things. Can we get a close up picture of that connector as well?
                                • bodaciuos
                                  • May 2011
                                  • 43
                                  Re: pn50b650s1f
                                  hers this pic of the board and pin in which im talking about. SS, SC..??
                                  • bodaciuos
                                    • May 2011
                                    • 43
                                    Re: pn50b650s1f
                                    so. i isolated and turn on the power supply by it self. nothing connect to it. by jumping PS ON to ground.(pin1 to pin 5) all voltages good . the only thing im not sure of is the PS-ON pin.(pin #1) doesnt give me a reading . is it suppose to ?.
                                    • bodaciuos
                                      • May 2011
                                      • 43
                                      Re: pn50b650s1f
                                      well got it to go. but im screwed.it has red vertical line left side of the screen. bummer.. well thanks for you help celeb-ro. (in case u where wondering celebro is spanish for brain).
                                      • Caleb
                                        Smokin IC's
                                        • Feb 2013
                                        • 645
                                        Re: pn50b650s1f
                                        Sorry I have been working on panasonics as of late they call the ysus sc and the xsus ss. It does appear you may have a bad panel, Maybe tom will chime in with his expert opinion. It may have a slight chance of failure in that bottom buffer, especially since the fuse was blown. Those bottom boards are usually 10-15$. (edit tried looking up replacement part and came to the realization yours are bonded to the panel. you might try a little pressure on the ribbon contacts and see if it will go away.) Pson will not give a reading on the power supply, the signal is coming from the main board back to the power supply.
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • DqMagetz
                                          Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                          by DqMagetz
                                          Good day!
                                          I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                          Here are the voltage readings:
                                          • Input – 19V (stable)
                                          • +LCDVDD – 3.3V briefly, then drops to 0V
                                          • EDP_HPD – 3.3V briefly, then drops to 0V
                                          • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                          • EC BKOFF# – 1.8V briefly, then drops to 0V
                                          • PANEL_OD_EN – 0.3V
                                          Is it possible that the EC chip is corrupted or damag...
                                          07-12-2025, 09:37 PM
                                        • Ven
                                          Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                          by Ven
                                          Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                          Issue Description:
                                          1. CPU Overheating to 100°C
                                            • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                            • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                            • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                            • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                            • Thermal
                                          02-12-2025, 03:57 PM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
