having voltage issues on my samsung plasma pn50b650s1f. at first i had no sound or picture. after a couple of replacement part. i at least have audio know. so getting to my issue is that when i plug it in audio boots up fine but with no pic. i check all the reading on power supply voltage is fine . but the no. 1 PS pn pin to control board goes from 3volt to 125 from stby to on . do i have a short maybe. has anyone ever have this issue..
pn50b650s1f
Re: pn50b650s1f
I doubt it is the ir board, What is the panel number on your tv, i can see the sticker in the picture with the xsus but cant read the fine print- I came up empty on the model# for a service manual. If your panel is primed (glows) you could still have a main board issue. you can try jumpering pins 3 and 4 on the control board with lvds unplugged and see if you get test patterns on the screen.Liberating magic smoke one part at a timeComment
Re: pn50b650s1f
thanks,, if u can find service manual. can u get it to me ? that will be great. sorry we may be in different time zone but in i WA state.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: pn50b650s1f
so i found a bad fuse on the e buffer board blown at least i think that what its called ,bottom of the tv. its on f2500. it says f8r on it. any one know where i could find this fuse? or a compatible one. also i remove the plug and im hoping there in the right position. if any one can verify if the plug are on correct. thatll be great. if u notice the blue dot that will be my reference.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: pn50b650s1f
tried to get a test pattern, no good. but by looked at the screen carefully. it has a 5 inch lighter glow on each side than the middle of the screen. if thats any help or indication of a specific problem.I doubt it is the ir board, What is the panel number on your tv, i can see the sticker in the picture with the xsus but cant read the fine print- I came up empty on the model# for a service manual. If your panel is primed (glows) you could still have a main board issue. you can try jumpering pins 3 and 4 on the control board with lvds unplugged and see if you get test patterns on the screen.
Re: pn50b650s1f
The connections are OK compared to another model I did recently.
It's important that you DO NOT unplug/plug in that connector while the unit is running.
Not only will the fuse often blow it can also damage the plasma panel drivers which are non replaceable!
Also, you absolutely MUST have the heatsink bolted on them while running it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: pn50b650s1f
this is the closest thing to your tv sm I could find, attaching the quick start sheet as well for a similar model. Im not sure what the rating on that fuse is, however you should test the outbound side of that fuse against ground to see if you have a short present before replacing.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: pn50b650s1f
are you saying your getting 126 volts on the standby circuit? 126v would be ok in parts of the power supply but certainly not on the standby circuit. You should have about 120 volts on the ac side of the bridge rectifier, if the pfc isnt working you might find that on the filter cap although it should be up in the 170v range before the supply turns on then bump up to about 350 volts or more.
It would probably be best if you note the supply voltages that are marked on your tv and compare them to the readings you have on each connector. Also make sure you are using the right setting on your multimeter (with a good battery) and the proper ground point for the section you are testing. You may be getting erroneous readings otherwise.Liberating magic smoke one part at a timeComment
Re: pn50b650s1f
yes you are correct. this is my voltages . cn108 pin 1 of 24 pins. three volt stby. when i turn on the set, it goes to 123-126 vlts. getting 5.3 volt on stby pin 5,and stays there when i turn the unit on . i believe pin 5 stby pin is supose to drop. voltage on y buffer are correct and xsus r correct ..Last edited by bodaciuos; 03-26-2014, 09:05 PM.Comment
Re: pn50b650s1f
I would try to isolate that 126v, see if it is coming from the power board or coming off sc or ss. If you have two circuits tied together it could be bad for the components on the low voltage side of things. Can we get a close up picture of that connector as well?Last edited by Caleb; 03-26-2014, 11:22 PM.Liberating magic smoke one part at a timeComment
Re: pn50b650s1f
so. i isolated and turn on the power supply by it self. nothing connect to it. by jumping PS ON to ground.(pin1 to pin 5) all voltages good . the only thing im not sure of is the PS-ON pin.(pin #1) doesnt give me a reading . is it suppose to ?.Comment
Re: pn50b650s1f
well got it to go. but im screwed.it has red vertical line left side of the screen. bummer.. well thanks for you help celeb-ro. (in case u where wondering celebro is spanish for brain).Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: pn50b650s1f
Sorry I have been working on panasonics as of late they call the ysus sc and the xsus ss. It does appear you may have a bad panel, Maybe tom will chime in with his expert opinion. It may have a slight chance of failure in that bottom buffer, especially since the fuse was blown. Those bottom boards are usually 10-15$. (edit tried looking up replacement part and came to the realization yours are bonded to the panel. you might try a little pressure on the ribbon contacts and see if it will go away.) Pson will not give a reading on the power supply, the signal is coming from the main board back to the power supply.Last edited by Caleb; 03-28-2014, 09:37 AM.Liberating magic smoke one part at a timeComment
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by DqMagetzGood day!
I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
Here are the voltage readings:- Input – 19V (stable)
- +LCDVDD – 3.3V briefly, then drops to 0V
- EDP_HPD – 3.3V briefly, then drops to 0V
- PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
- EC BKOFF# – 1.8V briefly, then drops to 0V
- PANEL_OD_EN – 0.3V
Is it possible that the EC chip is corrupted or damag...2 Photos -
by VenDell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
Issue Description:- CPU Overheating to 100°C
- When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.
- When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
- However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
- I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
- Thermal
2 Photos - CPU Overheating to 100°C
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
Product Name: Razer Blade 15 (2022)
Product ID: RZ09-0421
Motherboard: CH580
BIOS Versions I work with: 2.02 & 2.06
Bios File Size: 32,768 KB
Dear Forum Readers!
I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
!!! MY RAZER BLADE...-
Channel: BIOS Requests ONLY!
11-24-2025, 05:52 PM -
- Loading...
SS, SC..??
