Smd fuse replacement
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Ok so I have a smd fuse 3a on a main board I have that needs to be replaced. I don't have any extra ones but I do have a 5a laying around. Would it really be that bad to put the 5a in place of the 3a. Or do I need to order a 3a.
  • paulstef
    • Dec 2013
    • 724
    Re: Smd fuse replacement
    As long as everything works fine you can even put in a 200A fuse. Or a nail. :-)
    I would always avoid replacing them with others having higher current rating.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Haha. I might just do it anyway. I'm hoping it will fix the problem w/ the main board.
      • Thomas Capper
        • May 2013
        • 19
        • usa
        I have seen various warnings in tv's, home electricity, and car fuses that you should always replace the fuse with the same type/amperage.
        • paulstef
          • Dec 2013
          • 724
          Ah, ok, you still have a problem with the board? In that case do not replace it with a fuse with a higher current rating. It gets damaged for a reason. You may end up damaging traces if you pass too much current through them.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Yea it still didn't fix the problem. I'm almost completely exhausted on this tv. I checked all fuses for voltage. All caps good. All points on power board getting correct voltage. I have no idea where to go one this one. The heat shield on the main board still gets kinda warm. Not so warm it burns but enough to notice. The tv is a m550nv vizio that when plugged it logo flashes for a while then goes to stand by. U turn it on and the backlight turns on but no picture on screen. If u hit the power button to turn on menu the screen dims but no image.
            • paulstef
              • Dec 2013
              • 724
              Ok, so something draws too much current. You don't happen to have access to infrared camera?
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                No I don't. Left it in my other spy bag. Lol jk. But originally I had to replace a melted capacitor that was underneath side of the main board next to where the heat shield would be.
                • paulstef
                  • Dec 2013
                  • 724
                  Do you have the service manual, schematic? Do you have an oscilloscope?
                  • audiofreak19
                    • Apr 2013
                    • 556
                    • usa
                    I dot think they have a service manual for it. And I only have a dmm
                    • paulstef
                      • Dec 2013
                      • 724
                      Can you post a pic of the region where u said you replaced a melted cap?
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        K
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          Here's another
                          • audiofreak19
                            • Apr 2013
                            • 556
                            • usa
                            This was before I replaced the smd cap
                            • paulstef
                              • Dec 2013
                              • 724
                              So somebody already tried to repair the set before you did?
                              It doesn't look "melted". Was it shorted? What is it connected to? VCC GND etc?
                              • audiofreak19
                                • Apr 2013
                                • 556
                                • usa
                                I don't know what it was connected to but the last picture showed the plastic part melted down. So I replaced it but did a real bad solder job.
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  The cap on the last picture has very likely not been mounted like this in factory. Somebody replaced it already. Was it shorted?
                                  You can determine what it is connected to when you follow the traces back to the power supply. I assume it to be on GND on one side and on 3V3 or %V on the other side.
                                  • audiofreak19
                                    • Apr 2013
                                    • 556
                                    • usa
                                    I wasn't sure. I don't have the board infront of me right now. Before I replaced the cap the tv wouldn't even power on or have the logo light up. And after I replaced it it will turn on but no image.
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      Measure the voltage on that cap. Multimeter first DC, then AC. Post the results.
                                      If possible get a scope borrowed from someone.
                                      • audiofreak19
                                        • Apr 2013
                                        • 556
                                        • usa
                                        K
                                        • nickgronk
                                          64PN5500 | BN44-00618A Main fuse keeps popping
                                          by nickgronk
                                          Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
                                          I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
                                          The main fuse (T12AH250V) blew
                                          I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped...
                                          01-22-2022, 10:43 PM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • whc14765
                                          Replacement Fuse - 980TI Gigabyte
                                          by whc14765
                                          I have a GIGABYTE Windforce 980TI with a blown fuse. I have already found the root cause for the fuse blowing.
                                          I need help getting a replacement fuse - I'm fine with waiting some time for some cheap ones from China.
                                          The fuse says 10A on it. And I'm not sure what package size it is exactly. Also, how do I know if it is a fast or slow fuse?
                                          04-11-2022, 09:01 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • dimis7
                                          LG 37LS5600 blows main fuse
                                          by dimis7
                                          Need some advice to troubleshoot this TV.
                                          PSU blow the main fuse F100, 3.15A.
                                          I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                                          I checked with DMM for dead sorts but didn't found any.
                                          Checked bridge rectifier and seems ok.
                                          Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                                          PSU p/n is EAX64405901 (1.6)...
                                          10-28-2022, 05:15 AM
