very bright white area on Samsung LA32S81BX/XST
  • massimo23
    • Mar 2014
    • 13
    • ireland
    Hi there, i am having a problem with my Samsung LA32S81BX/XST Tv.
    When i stand in front of my tv the screen viewing is ok but if i move on either side of it i get a bright white halo as seen on the photos i attached.
    I opened the back of the tv and the only thing i noticed immediately is a bulged capacitor of 1000 microfarad 25V (top left capacitor in image 1). Could this cause the problem?
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: very bright white area on Samsung LA32S81BX/XST
    yes,that cap could cause problems,as it is part of the inverter circuit,replace with panasonic fc/fm/fr series
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • massimo23
      • Mar 2014
      • 13
      • ireland
      thank you for your quick reply multimeter. i will do that tomorrow and let you know. Thanks
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        if you want more longevity out of the set,you only have a few caps there to replace,id ignore the large filter cap,as these rarely fail,but replace the rest
        • ecking767
          • Oct 2009
          • 492
          its your T-CON board, take close up picture. its could be a burn out AS15 chip.
          • massimo23
            • Mar 2014
            • 13
            • ireland
            I will change the caps and see what happens.
            multimeter you don't by any chance know the values of the other caps.
            i would have to reopen the tv and search one by one.
              Make sure to use high quality capacitors e.g. Panasonic FM/FR/FC. Do not use generics/Maplin specials/etc.
              You should verify installed values, because the manufacturer can change them in later versions but not update the schematic.
              • massimo23
                • Mar 2014
                • 13
                • ireland
                ok thanks tom66.
                • massimo23
                  • Mar 2014
                  • 13
                  • ireland
                  hi guys i finally replaced the caps but still have the same problem...
                  My tv is nearly 9 years old..could it be the lcd panel itself ?
                  The screen always gets very hot, that i see and feel markings (long bumps) on the top right of the screen.
                  Maybe better to buy a new Tv when it fails eventually rather then replacing the panel, am i correct?
                  The AS15 chip is fine, was some dirt from spider webs, a bit everywhere...
                  Thanks all.
                  • vlado64
                    • Mar 2008
                    • 7
                    Photo T-com and number panel
                    • Fasinphil
                      • Jun 2016
                      • Philippines
                      Has anyone found a solution to this problem? I have the same issue as OP. Samsung service sucks,rather do it myself.
                      • SLK001
                        • May 2014
                        • 264
                        If the output voltages from the inverter are identical, then I would suspect aging CCFL tubes, then the panel. You can zero in to the problem by removing the panel from the backlight and seeing if the problem still exists. If so, then try replacing the CCFLs. If it is gone, then your panel is probably going bad.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Looks like tab bond issue to me.
                            Did you do any GAMMA DCV testing on the T-CON board?
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                            • tech9pc
                              Samsung QN65Q80AAFXZC QLED TV has a white vertical Bar
                              by tech9pc
                              Hi all Happy Holidays! Was just wondering if you think this white vertical bar would be fixable. Maybe bad TCon or ribbon cable? Contemplating trading a 50 inch Hisense 4K Roku for the Samsung but might get burned lol. The Samsung is model QN65Q80AAFXZC QLED TV has a white vertical Bar. Any thought appreciated. Thanks.
                              12-24-2023, 11:28 AM
