Samsung UE75TU6905 reboot loop
+ More Options
Posts
  • Admin
    • Oct 2003
    • 5334
    • United Kingdom
    nomoresonys is back after some discussion. rules need to be followed
      • 12201
      • U.S.
      Lol, yeah, the mods are correct, I'm the bad apple. Taking a vacation from badcaps, might see you in the future, maybe.
      • brkie
        Random guy
        • Sep 2024
        • 14
        • Sweden
        Originally posted by Diah
        you used the Tv as presentation..as you said... with which source ? HDMI or USB ?
        from yours fault description it show the logo then Tizen then make reboot... this mean after Tizen usually the set with switch on the last source where it working on.... so if it was HDMI it could the source switch damaged or it set on solution which TV didnt understand it... try trik the TV to put it in STBY and from STBY state call service menu from there do hard reset.
        or use the last source input with content low resolution not 4K lower you have even if 480p
        Used with HDMI, we hade it at work for screen mirror from PC some times, max 10 hours of use...
        This is what I've done: disconnected the TV, removed the back panel, disconnected the motherboard from the power cord, it does NOT reboot.
        Reconnect the motherboard, it reboots. Disconnect the flat cable from motherboard, it doesn't reboot. Sound is present the whole time.
        • lotas
          • Jan 2016
          • 4611
          • Russia
          This indicates that the panel is faulty.
          There are U-shaped cables on the strips that connect these punks to each other, disconnect them on one side and check for reboot, then do the same on the other side and then you can determine which side the problem is on.
          • brkie
            Random guy
            • Sep 2024
            • 14
            • Sweden
            Thanks, so it's not the motherboard? And I guess the panel isn't something you can replace, so it's just taking it to the dump?
            • lotas
              • Jan 2016
              • 4611
              • Russia
              #26
              Take a good photo of these bottom bars.
              • brkie
                Random guy
                • Sep 2024
                • 14
                • Sweden
                #27
                Left from home but I had a photo of this if thats what you mean:
                • lotas
                  • Jan 2016
                  • 4611
                  • Russia
                  #28
                  Yes, they are, but I need photos of them in their entirety, especially the ends of the left and right strips.
                  • Diah
                    • Feb 2013
                    • 6376
                    then you have on the right side ( when you look from the back) at the end of panel puffer boards there are 4 ESD diode.at the section remarked E8 .. one could be shorted as its protect at time the resolution came from HDMI
                    • brkie
                      Random guy
                      • Sep 2024
                      • 14
                      • Sweden
                      #30
                      • brkie
                        Random guy
                        • Sep 2024
                        • 14
                        • Sweden
                        #31
                        Can i check somehow?
                        • lotas
                          • Jan 2016
                          • 4611
                          • Russia
                          #32
                          You don't understand, I don't need these trains, but a photo of this green strip in its entirety, from one end to the other, the full length, maybe a photo in pieces.
                          You can disconnect the speakers.
                          • Diah
                            • Feb 2013
                            • 6376
                            why you upload photo of yours power boards.... yours issue at the panel puffer boards which you show the u ribbon disconnected... look on the right side after you take out the speaker at the end of the boards you will be able to see pack of ESD diode.... or you have problem with language ?
                            • brkie
                              Random guy
                              • Sep 2024
                              • 14
                              • Sweden
                              #34
                              Sorry, my English is not the best nor the terms of parts in a TV. Thx for your help
                              • lotas
                                • Jan 2016
                                • 4611
                                • Russia
                                #35
                                Remove this tape and take close-up photos of these areas.
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  nothings under the type as i member... the pack of ESD are little to left top of the right side.... each diode with 6 pins.
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    zoom here.. i thing here are the 4 ESD
                                    • lotas
                                      • Jan 2016
                                      • 4611
                                      • Russia
                                      #38
                                      Yes, I don’t like the look under the tape, as if there was corrosion there from the glue.
                                      • Diah
                                        • Feb 2013
                                        • 6376
                                        exactly... its paper type... not chassis type,,, it may make short too,,, so he need to take them out from both side
                                        • lotas
                                          • Jan 2016
                                          • 4611
                                          • Russia
                                          #40
                                          Can't remove the tape?
                                          Yes, here I think for a long time...
                                          • kevin_allein
                                            Samsung GU58TU7199 reboot loop
                                            by kevin_allein
                                            Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                                            The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                                            03-24-2024, 12:19 PM
                                          • Takeatry
                                            Yet another Samsung QLED Boot Loop
                                            by Takeatry
                                            Samsung QLED QN50Q β€” purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                            10-04-2024, 02:57 PM
                                          • natiz
                                            Samsung QE50Q60AA - Reboot loop
                                            by natiz
                                            I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                            Disconnecting the LVDS cable stops the restart loop but no image.
                                            I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                            Tested the caps on the left buffer board, no beeps.
                                            What else can be checked?...
                                            08-30-2024, 09:26 AM
                                            09-07-2024, 05:50 AM
                                          • Yanleb
                                            Samsung 4K UN55NU7100F stuck in a reboot loop
                                            by Yanleb
                                            Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                                            I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                                            I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                                            On a few occasions I found that reconnecting the disconnected LVDS...
                                            03-19-2022, 02:13 AM
