Samsung 4K UN55NU7100F stuck in a reboot loop
  • Yanleb
    • May 2017
    • 108
    Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
    I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
    I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
    On a few occasions I found that reconnecting the disconnected LVDS cable while the TV was still on allowed it to run with a very good picture. It allowed me to perform a factory reset, update the firmware and so on. But as soon as I power off the TV and try to power it on again it is still stuck in a reboot loop.
    The rest of the time when powering on the TV with one LVDS cable disconnected, then reconnect it (while it is still on) will cause it to reboot after a few seconds.
    The main board PCB model is BN41-02635B. This main board design is used in many TV sets:
    UN40NU6070FXZA
    UN40NU7100FXZA
    UN40NU7100FXZC
    UN40NU7200FXZA
    UN43NU7100FXZA
    UN49NU6300FXZA
    UN50NU7100FXZA
    UN50NU7100VXZA
    UN50NU710DFXZA
    UN50NU7200FXZA
    UN55NU7100FXZA
    UN55NU7300FXZA
    UN58MU6070EXZA
    UN65NU7100FXZA
    UN65NU7200FXZA
    UN65NU7300FXZA
    UN65NU730DFXZA
    UN65NU740DFXZA
    UN75NU7100FXZA
    UN75NU7100FXZC
    UN75NU7100FXZX
    UN75NU710DEXZA
    UN75NU710DFXZA
    UN75NU7200FXZA
    Another revision BN41-02635A of that PCB design is also used in the following TV sets:
    UN40NU7100FXZA
    UN43NU7100FXZA
    UN43NU710DFXZA
    UN50NU7100FXZA
    UN50NU7100VXZA
    UN50NU710DFXZA
    UN50NU7200FXZA
    UN50RU7100FXZA
    UN55NU7100FXZA
    UN55NU710DFXZA
    UN55NU7200FXZA
    UN55NU7300FXZA
    UN58NU7100FXZA
    UN58NU710DFXZA
    UN65NU7100FXZA
    UN65NU710DFXZA
    UN65NU7300FXZA
    UN65NU7300FXZC
    UN65NU740DFXZA
    UN75NU7100FXZA
    UN75NU7100FXZC
    UN75NU7100FXZX
    UN75NU710DEXZA
    UN75NU710DFXZA
    UN75NU7200FXZA
    When removing the metal cover at the bottom of the TV set I can easily do voltage measurements. The problem is that the majority of the test points have no meaningful labels like TEST1_2, TEST1_3 and so on.
    Do you have suggestions on what to check next?
    Thanks.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4555
    • Italy - Milan
    Re: Samsung 4K UN55NU7100F stuck in a reboot loop
    On the panel's distribution boards sits probably the problem, locate the possible diodes, one can try remove them, also try locate the avdd trace from main board, mask it and connect it through a power potentiometer, try until the screen turns on, locate some odd warm on the screen caps.. last, try insulate some pins on the ribbon cables until it stays on, if you own oscilloscope mask only clock lines
    • kevin_allein
      Samsung GU58TU7199 reboot loop
      by kevin_allein
      Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
      The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
      03-24-2024, 12:19 PM
    • brkie
      Samsung UE75TU6905 reboot loop
      by brkie
      I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
      I read on Samsung's website (reviews)...
      09-04-2024, 01:45 AM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • natiz
      Samsung QE50Q60AA - Reboot loop
      by natiz
      I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
      Disconnecting the LVDS cable stops the restart loop but no image.
      I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
      Tested the caps on the left buffer board, no beeps.
      What else can be checked?...
      08-30-2024, 09:26 AM
      09-07-2024, 05:50 AM
