Philips 43PUS8550 no image, backlight working
  • lotas
    • Jan 2016
    • 4555
    • Russia
    Compare with the working bar, it should be approximately the same.
    • pseudorc
      • Sep 2024
      • 12
      • United Kingdom
      Checked against bar and gnd, around 3.2 on both end of the resistor but in between the both end its 0
      Is that supposed to happen?
      • pseudorc
        • Sep 2024
        • 12
        • United Kingdom
        Here are some pics of what i was measuring
        • lotas
          • Jan 2016
          • 4555
          • Russia
          You measure relative to the ground, that contact goes through a resistor...
          I don’t have such a panel at the moment and I can’t measure how it should be, you have a working bar on the other side and compare the readings with it.
          • Diah
            • Feb 2013
            • 6357
            This is the first time I've heard this, did you come up with it yourself?
            be thankfull to one try to explain for you part of huge subject how IPS work with OP testing of ribbon disconnected...
            but you are child and this your ways to push other.. yours age or any parts of yours life will never catch 10% of my working profile life include degree... i do feel my self happy when i explain some things to other... but if the other become rude like you..... no excuse of hard answer you will hear from me..
            who delete my previous answer to you... his brain blocked too as this remarked sentence he passed it away.. and most user they know who i am...
            so stop from this art of writing, and don't copy from other portal to post over here ... i am old member over the famous Russian 4pda--- just take caution.
            • lotas
              • Jan 2016
              • 4555
              • Russia
              #26
              I’m approaching 60 years old, and I’m no longer a child, and if I’m confident in my advice, then I give it...
              • Diah
                • Feb 2013
                • 6357
                good to hear you are no more child... by approaching the 60th , don't be confident unless you had studied / worked or faced same issue to advice with explanation .. that's all
                • lotas
                  • Jan 2016
                  • 4555
                  • Russia
                  #28
                  Yes, all knowledge and practice comes with age, but technology does not stand still...​
                  • pseudorc
                    • Sep 2024
                    • 12
                    • United Kingdom
                    #29
                    So actually this wasn;t a MB issue at all, I have capped/taped some connection showing in the picture and the voltage and screen is back. I guess the issue is either in scaler PCB somewhere or connection to the half LCD panel itself, can't fix it in that case at home.
                    anyone knows if i keep this that way what to expect?
                    • lotas
                      • Jan 2016
                      • 4555
                      • Russia
                      #30
                      Yes, as I wrote above, this is a problem in the panel, leave it like that, if you are satisfied with the image, there is nothing better you can do.
                      • atkallu
                        Philips 58PUS8545 t-con problem or something else ?
                        by atkallu
                        Hello
                        I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                        See the attached image.
                        I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                        But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                        T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                        01-13-2025, 11:23 AM
                      • tuner2000i
                        Philips 65PUS8518/12 distorted image after main board replacement
                        by tuner2000i
                        hello everyone,
                        I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                        The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                        07-15-2025, 01:15 PM
                      • malekservis
                        Philips 58PUS8536/12 Backlight ok, no image
                        by malekservis
                        the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                        Any information would be appreciated....
                        08-07-2024, 07:48 AM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • Kartowl
                        philips 47pfl6158k/12 image faded away, sound still coming from TV
                        by Kartowl
                        Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                        04-23-2024, 12:57 AM
