Philips 43PUS8550 no image, backlight working
  • pseudorc
    • Sep 2024
    • 12
    • United Kingdom
    Checking voltages at TCON
    Vin 12 V ok BUT ALL OTHER VOLTAGES 0
    VGL1 0
    VDD
    vcc19
    VGH 0
    when connection to Left half screen cable disconnected - then other half becomes white and voltages shows down below
    VGH 27.96
    VCC19 1.89
    HVDD 8.31
    VGL1 5V
    VGL2 3.8
    TCON board has been replaced with similar (bought from Ebay)
    Is this LCD panel issue ? the parts showing parts no is lg 6870s-2704d
    Many thanksClick image for larger version
  • Diah
    • Feb 2013
    • 6363
    if you disconnect one ribbon between T-CON and panel.. then u have clear half white on screen.... it mean the MB didnt send full channel GPU signal.... with Philips we do downgrade the firmware with upgrade_loader-pkg firmware
    BTW be sure from yours TV model No !
    • pseudorc
      • Sep 2024
      • 12
      • United Kingdom
      Hi, thanks for your response.
      Is it not supposed to happen on the other side as well ? I mean when disconnect other ribbon keeping the left one should it not replicate the white line?
      Is there any downgrade firmware how to process/instruction written up anywhere please ?
      Also the TV model no should be 8555 , not sure how to change it now
      • Diah
        • Feb 2013
        • 6363
        still wrong No...LOL
        • pseudorc
          • Sep 2024
          • 12
          • United Kingdom
          How about PHILIPS 43PUS8555/12 43" Smart 4K Ultra HD HDR LED TV !
          • Diah
            • Feb 2013
            • 6363
            ok, its TPM191E 8505/8535/8545/8555 Performance Series
            which it share same FW with OLED.... from years 2020, you have here in this forum thread i posted of file eed you can flash it... or downgrade with upgrade loader-pkg android 11 or 9...
            usb stick need formatted FAT32 NBR mode... more info you finf´d on this link
            • pseudorc
              • Sep 2024
              • 12
              • United Kingdom
              Attempted downgrading , did not work , tried blindly though keeping the drive for at least 40 min
              • Diah
                • Feb 2013
                • 6363
                some things wrong you did.... stick must in MBR mode formated FAT32,,,,, use the USB port on the side USB 2 black not blue..... at same link the side i gave it to you download another version upgrade_loader
                • lotas
                  • Jan 2016
                  • 4580
                  • Russia
                  If you disconnect the cable from this half and voltage appears on the t-con, it means that this half is shorting out some voltage and the t-con goes into protection, take a high-quality photo of this entire strip.
                  • pseudorc
                    • Sep 2024
                    • 12
                    • United Kingdom
                    Here are the pics
                    • lotas
                      • Jan 2016
                      • 4580
                      • Russia
                      Disconnect the lvds cable and check the resistance at these points relative to ground (on the bar itself), it should not be low or short circuited, and also check the resistance at all ceramic capacitors on the entire bar.
                      • Diah
                        • Feb 2013
                        • 6363
                        MAN and you OP.. you have disconnected one ribbon and got half screen white but other half no image.... what are you both doing ? why playing with panel... its IPS panel who want to work on it nead to learn first how IPS working... and this why you disconnected other ribbon and no white screen display..... its funny... really funny going on here. good luck for destroying the set.,,, this is my last.
                        • lotas
                          • Jan 2016
                          • 4580
                          • Russia
                          Why are the output voltages on the T-con blocked when the non-working half is connected? Is this a software problem?
                          • Diah
                            • Feb 2013
                            • 6363
                            take look on the T-con main IC... and search after IPS how video channel delivered to gate transistor. , VIA tech are absolute different yours suspect will be in place.
                            • lotas
                              • Jan 2016
                              • 4580
                              • Russia
                              And here IPS or VIA, if the T-con blocks the voltage when connecting the faulty side.​
                              • Diah
                                • Feb 2013
                                • 6363
                                IPS depending on MB delivery... one channel or 2 channel signal , it will bw some design till 4 P1+--P4+ & p1- to p4- at the end all MB FW first then HW
                                • lotas
                                  • Jan 2016
                                  • 4580
                                  • Russia
                                  VGL1 0
                                  VDD
                                  vcc19
                                  VGH 0
                                  VGH 27.96
                                  VCC19 1.89
                                  HVDD 8.31
                                  VGL1 5V
                                  VGL2 3.8
                                  Voltages should not disappear (VGH, VGL,...) if the panel is working properly!
                                  • Diah
                                    • Feb 2013
                                    • 6363
                                    man VGH or VGL will not present if no signal... its not fix V.. its range of Hz freq, and current which T-CON assign them to cell gate - one channel fault at PS or MB HW cause this in case you did used replacement T-CON at IPS account
                                    • lotas
                                      • Jan 2016
                                      • 4580
                                      • Russia
                                      This is the first time I've heard this, did you come up with it yourself?
                                      So there is no signal, but when the non-working half of the voltage is turned off, for some reason the voltage is restored.
                                      What do you advise everyone then? To put the panel into offline mode, you just need to disconnect the LVDS cable and apply 12 V to the T-con fuse and the panel will alternate colors, so where do the voltages come from (VGH, VHL...) if there is no signal.
                                      • pseudorc
                                        • Sep 2024
                                        • 12
                                        • United Kingdom
                                        Caps looks fine, however R2015 seems shorted whereas others are showing 299 Ω , and not getting any reading from D24 except the top middle one 30 Ω.
                                        • atkallu
                                          Philips 58PUS8545 t-con problem or something else ?
                                          by atkallu
                                          Hello
                                          I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                                          See the attached image.
                                          I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                                          But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                                          T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                                          01-13-2025, 11:23 AM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
                                        • malekservis
                                          Philips 58PUS8536/12 Backlight ok, no image
                                          by malekservis
                                          the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                                          Any information would be appreciated....
                                          08-07-2024, 07:48 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Kartowl
                                          philips 47pfl6158k/12 image faded away, sound still coming from TV
                                          by Kartowl
                                          Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                          04-23-2024, 12:57 AM
