Samsung QE50Q60AA - Reboot loop
  • natiz
    • Aug 2018
    • 18
    • ME
    I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
    Disconnecting the LVDS cable stops the restart loop but no image.
    I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
    Tested the caps on the left buffer board, no beeps.
    What else can be checked?
  • EazyBone
    • Jun 2023
    • 1315
    • United states
    Does this have diode packs? Show pictures of full buffer boards. And how many pins are you blocking with tape at a time?
    • natiz
      • Aug 2018
      • 18
      • ME
      No diode packs, attached full board.
      I tried many variations, among this: https://www.badcaps.net/forum/troubl...95#post1840595
      • EazyBone
        • Jun 2023
        • 1315
        • United states
        Is this damage in the picture? On the ribbon.
        But if above don't work, you are probably screwed. There isn't much of a solution for these yet that I've seen on here for the Samsung reboot besides diode pack/tape and occasionally bad caps on buffers.
        • natiz
          • Aug 2018
          • 18
          • ME
          That side of the ribbon does have a bit of a bend on the side but it doesn't look damaged.
          As for the the tape method, wanted to make sure, those are the pins the need to be masked?
          • lotas
            • Jan 2016
            • 4557
            • Russia
            You have these test points on each strip, disconnect the U - cable and the LVDS cable and check the resistance on them relative to ground and relative to each other (that is, 1 to 2, 1 to 3, 1 to 4, ... 2 to 3 , 2 from 4,... and so on with everyone).
            • natiz
              • Aug 2018
              • 18
              • ME
              I sampled the CK* against ground they seem ok but will double check tomorrow.
              I am concerned about VGH that measured ~80M while on the other board it measures 5K.
              Assuming that's the culprit do I mask only VGH?
              Found the mapping on this post https://www.badcaps.net/forum/troubl...58#post1786858
              Click image for larger version  Name:	fetch?id=2116618.jpg Views:	0 Size:	349.5 KB ID:	3340298
              • lotas
                • Jan 2016
                • 4557
                • Russia
                You need to check not only with respect to the ground, but also with each other, and there will be many options there.
                • EazyBone
                  • Jun 2023
                  • 1315
                  • United states
                  Generally you move the tape around and try different spots.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4304
                    • Italy - Milan
                    if you have oscilloscope or frquency meter you can measure CLK / CKx lines, them have to be around 15khz maybe, plus STV around 100hz, LC1,LC2 i don't know.. check.also their voltage
                    • kevin_allein
                      Samsung GU58TU7199 reboot loop
                      by kevin_allein
                      Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                      The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                      03-24-2024, 12:19 PM
                    • brkie
                      Samsung UE75TU6905 reboot loop
                      by brkie
                      I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                      I read on Samsung's website (reviews)...
                      09-04-2024, 01:45 AM
                      09-07-2024, 05:50 AM
                    • Yanleb
                      Samsung 4K UN55NU7100F stuck in a reboot loop
                      by Yanleb
                      Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                      I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                      I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                      On a few occasions I found that reconnecting the disconnected LVDS...
                      03-19-2022, 02:13 AM
                    • eigma
                      Samsung UN40H5003 boot loop every ~8 seconds
                      by eigma
                      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                      Main board: BN94-07592P / BN97-08922R...
                      11-20-2024, 10:31 PM
