Vizio VX32L tv just stays in standby mode
  • catfish69
    • Jul 2012
    • usa
    i have checked all the fuses and all the standby voltages on the board and all of those are ok...on plug J1 pin one its supposed to b 3.3v mine is jumping all over the place but staying on mv instead of volts. the smd fuse right below J1 shows 5v on both sides but the fuse to the right of that one that is F2 shows mv on both sides and not v...there originally were two bad caps on power supply and untill i changed those there was no life at all...now at least i have the standby logo lighting up but thats it..it will not power up makes not clicks or noise of any kind and all the standby voltages r good but the rest of the voltages are all over the place and in mv not v.....i am cornfused...any help would b greatly appreciated.....thanks
    master hoarder
    • May 2008
    • 12175
    Re: Vizio VX32L tv just stays in standby mode
    Please start by posting some pictures of the boards of your set (bottom and top side). That way, we can better see what you are seeing and possibly suggest what else to check on the power board.
    Personally, I suspect you have more bad caps. If you had two, and there are others of the same brand, that means they aren't far behind and could be failed without showing it. Or likely the start-up caps are bad - they almost always do so without showing it.
    But again, we will need pictures to point you to the start-up cap and other items that may need checking.
    • Ltank
      • Jun 2013
      • 776
      Service manual for set
