lg ps3000
  • tw2005
    • Oct 2011
    • 6458
    Re: lg ps3000
    Originally posted by tonyuk
    Does anyone have a guid on how to test ysus and buffers on this model
    As the guy who fixed my buffers befor said just becase my
    Meter does not beep don't mean buffers r any good
    Post #26, 50PS60 uses the same panel and boards.
    • tonyuk
      • Feb 2014
      • 238
      • uk
      #82
      Re: lg ps3000
      ok all sorted now working again
      • tw2005
        • Oct 2011
        • 6458
        Re: lg ps3000
        Really! Good to hear.
        Don't be shy, give us the details. how did you solve it?
        • tonyuk
          • Feb 2014
          • 238
          • uk
          #84
          Re: lg ps3000
          first i got a new multimeter as mine was not great then found 2 buffers blown on the top buffer board so removed some buffers from another board i had this is the first time ive done this took me a while but fitted 2 buffers tested again with meter and checked fine fitted buffer back into tv and result all worked
          • gatto
            LG 50PC56 keep burn Buffers Boards
            by gatto
            Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
            I have this LG 50PC56 which not display image on screen
            I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
            When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
            My question it is: I disconnect...
            05-04-2022, 01:35 AM
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • alfredomfr1
            TV Plasma LG 60PN5000 ZSUS 15v missing
            by alfredomfr1
            All Voltages are OK except ZSUS 15v.
            YSUS board disconnected still 15v missing.
            ZSUS was replaced: 15v missing.
            Any help will be appreciated...
            04-29-2022, 11:26 AM
          • reessi
            LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
            by reessi
            Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
            Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
            If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
            If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
            12-13-2017, 01:18 PM
          • csmith
            LG-60PN6550 Removing Buffers-Need Help
            by csmith
            Got replacement buffer boards but not sure how to remove the ribbons. unfastened tab but their not eager to come out. Any suggestions? Thank You!...
            08-21-2024, 01:34 PM
