LG-60PN6550 Removing Buffers-Need Help
  • csmith
    • Aug 2014
    • 46
    Got replacement buffer boards but not sure how to remove the ribbons. unfastened tab but their not eager to come out. Any suggestions? Thank You!
  • Diah
    • Feb 2013
    • 6562
    after you lifting the tab , spray alcohol inside and give time.. it may there one spark which hold the pin on pin together
    • csmith
      • Aug 2014
      • 46
      That worked like a charm! Thank you Mr Diah.
      • Diah
        • Feb 2013
        • 6562
        you welcome Mr. csmith ...
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • Jidis
          Need T-Con Advice (Vizio P602ui-B3)
          by Jidis
          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
          09-22-2025, 05:10 PM
        • howardc64
          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
          by howardc64
          TV was fixed just after removing Samsung's rear snap cover.
          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
          Maybe PSU->backlight connector didn't have a good contact?...
          07-23-2025, 12:34 AM
        • mustardcheese
          Question about removing the BIOS lock
          by mustardcheese
          Hi all, I have a Dell Latitude 7300 with a locked BIOS and I was curious about the process of removing the lock by editing the hex values of the bin and how to do it. Is editing the hex values of the dumped bios any different than flashing a new one that's already been unlocked? (I currently don't have the correct bin because I realize I accidentally dumped the wrong thing). I am very new to this any help or advice or references would be greatly appreciated. Thanks
          06-17-2025, 10:25 PM
        • tongshadow
          Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
          by tongshadow
          I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
          "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
          Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
          03-12-2023, 12:06 PM
