lg ps3000
  • tw2005
    • Oct 2011
    • 6458
    Re: lg ps3000
    Originally posted by tonyuk
    Does anyone have a guid on how to test ysus and buffers on this model
    As the guy who fixed my buffers befor said just becase my
    Meter does not beep don't mean buffers r any good
    Post #26, 50PS60 uses the same panel and boards.
    • tonyuk
      • Feb 2014
      • 238
      #82
      Re: lg ps3000
      ok all sorted now working again
      • tw2005
        • Oct 2011
        • 6458
        Re: lg ps3000
        Really! Good to hear.
        Don't be shy, give us the details. how did you solve it?
        • tonyuk
          • Feb 2014
          • 238
          #84
          Re: lg ps3000
          first i got a new multimeter as mine was not great then found 2 buffers blown on the top buffer board so removed some buffers from another board i had this is the first time ive done this took me a while but fitted 2 buffers tested again with meter and checked fine fitted buffer back into tv and result all worked
          • gatto
            LG 50PC56 keep burn Buffers Boards
            by gatto
            Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
            I have this LG 50PC56 which not display image on screen
            I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
            When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
            My question it is: I disconnect...
            05-04-2022, 01:35 AM
          • reessi
            LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
            by reessi
            Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
            Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
            If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
            If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
            12-13-2017, 01:18 PM
          • alfredomfr1
            TV Plasma LG 60PN5000 ZSUS 15v missing
            by alfredomfr1
            All Voltages are OK except ZSUS 15v.
            YSUS board disconnected still 15v missing.
            ZSUS was replaced: 15v missing.
            Any help will be appreciated...
            04-29-2022, 11:26 AM
          • csmith
            LG-60PN6550 Removing Buffers-Need Help
            by csmith
            Got replacement buffer boards but not sure how to remove the ribbons. unfastened tab but their not eager to come out. Any suggestions? Thank You!...
            08-21-2024, 01:34 PM
          • Salvatore057
            plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
            by Salvatore057
            I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
            Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
            I am lost, should I change the YSUS board? Is the YSUS board damaging...
            04-29-2018, 01:29 PM
