LG 50ga7400 programming
+ More Options
Posts
  • jose6326
    • May 2013
    • 707
    Is there a way to bypass the google account when setting up this tv?
    I tried the settings option with a regular antenna but it says need to select built in tuner.
    when i select the built in tuner it doesnt detect anything
    My friend doesnt have a google account or internet service he only wants to use this to watch regualr air channels
    • 12251
    • U.S.
    Maybe try this, if it don't work, you can scroll down to where it says contact us and try the chat, open 24/7: https://www.lg.com/us/support/help-l...20151006511119
    • jose6326
      • May 2013
      • 707
      Thanks but i tried that but it says i need to select the built in tuner but when i do that it says lineup not available and when i click next it it says "unfortunately videoinput setup has stopped"
        • 12251
        • U.S.
        Not sure, I would try the chat, keep them typing, somebody there must know how to do it.
        • Diah
          • Feb 2013
          • 6427
          create for him any profile with google as fake name and birth.. just the zip code keep it correct... activated the tV with new profile first then no need online at his home when he use it.
            • 12251
            • U.S.
            Maybe make note/write down details of the profile, in case you ever have to fiddle with it again.
            • jose6326
              • May 2013
              • 707
              I chatted with support and they said i cant bypass google account activation.
              i did ask them if i can use the tv without google account and they had me try the same steps i ttied then thry said i have to take in for repair lol
              i will create a google account for my friend and see if that works
                • 12251
                • U.S.
                Good call, I think the tv is working correctly, they just don't make it very easy for folks to operate.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4436
                  • Italy - Milan
                  It's very poor policy of LG to need connection to the f*** of goofle, i think the only way to gently accompany it inside his *** is to enter service mode through tablet/smartphone + ir blaster + wav files and search a bypass option for that.. salutes..
                  • lotas
                    • Jan 2016
                    • 4712
                    • Russia
                    Most likely the TV does not correspond to your region, is the model number "LG 50ga7400" written correctly?
                      • 12251
                      • U.S.
                      One thing that might make things easier is go in settings>system>Power>power on, and set it to the device you want to see at boot.
                      • R_J
                        • 9583
                        What are you using for an antenna to recieve the off air channels? You must have one connected, then scan the off air channels and you will recieve whatever is broadcasting in your local area.
                        • jose6326
                          • May 2013
                          • 707
                          Yes trying to receive air channels but it wont let me get to the scan function as i mentioned in previous replies
                          • R_J
                            • 9583
                            I tried looking for that model " 50ga7400" and find nothing
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              i was looking for a user manual etc for this set too advise i wonder if its a 50ga6400?
                              • Diah
                                • Feb 2013
                                • 6427
                                goof point from R_J .... first i wounded how it come LG asking for Google account... web OS had nothings to do... other things old TVs if they are working with air signal T will never catch any signal if the country / area had T2 signal.
                                • DXseekerMO
                                  Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
                                  by DXseekerMO
                                  I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
                                  As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
                                  09-15-2021, 05:15 PM
                                • araxnido
                                  Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                                  by araxnido
                                  Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                                  When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                                  06-10-2025, 09:26 PM
                                • Mark R
                                  Does Changing Out Caps In A Tuner Effect FM Reception
                                  by Mark R
                                  "TQ" Subject at hand is a Marantz 120 tuner. The tuner lit up but no output. Recapped the entire unit. Before it was working fine tuning in Stereo and Mono. Now it just about tunes Stereo and some of the mono stations are weak. Nothing else was changed. When you do hit a stereo station the stereo lamp will come on but flickers as it's trying to hold the MPX signal.
                                  I don't see how bringing the unit back with new caps checked by my Sencore LC103 would effect the FM section. Every Value is as it was from the factory?
                                  Any Thoughts?
                                  06-11-2024, 07:04 PM
                                • zlr8r
                                  Advice on newer EC chip programming eg. MEC5107-LJ BGA
                                  by zlr8r
                                  Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
                                  i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
                                  09-16-2025, 09:54 AM
                                • zesko
                                  MP2886A programming
                                  by zesko
                                  I have a board with a dead pwm on mp2886a. I order the chip without thinking about programming, and now I just realize my mistake.
                                  Someone know if it's 100% needed to program the chip ? And if so, how to program it ? I see some dedicated board and software but, software is a bit tricky to me, the bad part of the job...
                                  p.s : with the dead pwm chip, the GPU work fine when I disconnect the shorted pwm (6), with the new chip Pgood is 0 and the gpu doesn't start, so I guess it need to be programmed, or it's fake chip..
                                  p.s 2 : Sorry for my...
                                  07-28-2025, 02:07 PM
