Rca rlc3255a-b doa
  • Fwrothy
    • Feb 2014
    • 178
    Rca rlc3255a-b doa
    So I picked this up yesterday, no indicator lights.
    No SBV
    Fuse ok, no shorts and ~165vdc out from bridge.
    Looking for SCH, no luck yet...
    Re: Rca rlc3255a-b doa
    Closer pic of PSU? Does 5V come back when you pull the power to main board connector out? Any ticking/pulsing sound from power board?
    • Fwrothy
      • Feb 2014
      • 178
      No ticks or hums or clicking don't see any relays anyway..
      Tested SBV voltage with main board disconnected.
      165v at main cap as well.
      • Fwrothy
        • Feb 2014
        • 178
        Better psu pic...
          Is it MAGMEET MP118A? Pictures is not well focus.
          Try heating those two caps with hair dryer to see if the 5VSTBY will start up or replace them.
          • Fwrothy
            • Feb 2014
            • 178
            Just found it @sj- it's a mp116a.
            • Fwrothy
              • Feb 2014
              • 178
              Thanks Bud I'll give that a try!
              Ya under the magnifying glass the 100uF looks bulged(bigger blue )-didn't notice before...
              • Fwrothy
                • Feb 2014
                • 178
                No luck with the hair dryer. Did pull out both capacitors(100mF 35v & 10mF 100v),no shorts,charged them with ohmmeter and drain back with voltmeter idk.
                No luck with SCH either, so resorted to fishing.
                Did notice short across octo didn't seem right; lifted it it seem ok. There's a sot 6 pin IC in area no idea what it is???
                Found N MOSFET (F2HNK60Z) seems shorted , will pull next...
                All these components are associated with primary of low voltage transformer.
                • Fwrothy
                  • Feb 2014
                  • 178
                  MOSFET F2HNK60Z shorted D-S ....gate seemingly not shorted.
                  SOT6? PWM controller?
                  • Fwrothy
                    • Feb 2014
                    • 178
                    Yes looks to me like a FAN6862...
                    Seems fried; Vdd,gate,FB all shorted to ground. That explain fault at octo.
                    Can bad caps cause this?!
                      Blown FET can damage IC.
                      Replace IC, FET, and nearby resistors and diodes.
                      • Fwrothy
                        • Feb 2014
                        • 178
                        Thanks Tom, just repaired a similar situation but found some white residue on trace side of board oddly enough. Could that be leaked electrolyte?
                        • Fwrothy
                          • Feb 2014
                          • 178
                          So I got off my butt and found my camera, iPad doesn't seem to be cutting it.
                          Got a pic of the afore mentioned residue, looked like something I saw in 'worst soldering' thread (somebody had a go at it already I think), but what a difference, been squinting through the magnifying glass and camera lens for too long now I can see discrete component markings and ICs way better than naked eye! Would like to get an inexpensive USB microscope/camera...
                          Anyways, trying to get a parts list together and dunno how to spec PWM controller -mentioned a FAN6862 or similar a while back but there seems lots to choose from and I don't know anything about cross compatibility...
                          Any suggestions? Pic at least show package marking if that's any help.
                          • Fwrothy
                            • Feb 2014
                            • 178
                            Decided since I didn't have a SCH I'd try my hand at drawing one...at least the part that seems bad.
                            So here goes, most of it seems to make sense...any feedback would be appreciated on the plausibility of the circuits I've tried to interpret.
                            Btw q9 is the bad/ shorted MOSFET and there are various resistors hi-lighted that look damage as well as no reading/OL.
                              R80/R81 will likely be low ohms. Are they through hole? Completely unreadable?
                              R73: typically 2~3x R74 value non-critical
                              R74: around 22 to 56 ohms check IC2 datasheet
                              • Fwrothy
                                • Feb 2014
                                • 178
                                I think the last pic shows them, r80/81 look like 4 digits.
                                They are all SMDs... Biggest issue is I don't know what IC2 IS...just guessing by pin layout .
                                  Looks like 2R20 i.e. 2.2 ohms which is about right.
                                  Couldn't find any info on that IC either.
                                  • Fwrothy
                                    • Feb 2014
                                    • 178
                                    Ya it's a bugger... There are a few in the Fairchild roster that seem like they could work but idk how pick or compatibility issues. It's a $40 psu and available, plus the trace is lifting a bit (probably my fault when re&re ec7)-just trying to challenge myself.
                                    Thanks for the input appreciated as always
                                    Better pic..
                                      If you do not get any where with it, replacement is not too bad.
                                      http://www.shopjimmy.com/megmeet-mp1...upply-unit.htm
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • Dani_2024
                                        by Dani_2024
                                        10-28-2024, 05:06 PM
                                      • ygorsan
                                        by ygorsan
                                        🧩 Problem Summary:
                                        • I
                                        Today, 08:34 AM
                                      • Ross Kohler
                                        Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                        by Ross Kohler
                                        I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                        - There's no sign of any attempt to power on when pushing the power button.
                                        - No PSON signal is reaching the 24-pin ATX connector.
                                        - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                        - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                        - If I pull the Super IO S_SLPS#_R pin...
                                        04-16-2024, 09:36 AM
                                      • Asraf Atb
                                        by Asraf Atb
                                        01-27-2025, 05:02 PM
