Hi all does anybody have any experience with the said psu, picked up a 42inch plasma the other day, the psu has no power and am struggling to find a replacement cheers
usp440m-42lp psu
Re: usp440m-42lp psu
What tests have you done on it?
Stby 5v present?
Have you tried turning the PSU on by sending the PS-On, Vs-On, etc to it?
What set? PSU may well be fine--could be a Set fault and nothing to do with the PSU at all!TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
i have checked the voltage on the points marked in yellow, nothing at all no standby light nothing. i have done a minimal amount of checks as i was just going to replace psu. there is a big blue block (relay i think ) found a post somewhere saying it might be that, its a bush 42" PLASMA, i do not have model number as of yetLast edited by joehezzer; 03-09-2014, 05:46 AM.Comment
Fuse is good?
Early Bush plasma - probably early LG panel - 42V5/V6/V7? If so watch out for sparklies/maldischarge fault.
I'd check input fuse and bridge rectifier for DC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Pics of chassis....?
--I'll bet that PSU is OK from experience....TELEFIX
Ha! A V7!
First plasma I ever potched with was a V7. Still got an alleged brand-new IPM for one kicking round somewhere....
10-1 that PSU is OK. You'll need to check for 5V stdby supply first before going any further.TELEFIX
Thing is--The V7 is pretty long in the tooth now, and only a 480p res, so not worth spending any real dosh on--certainly not investing say 50 quid in a PSU!
A few tests will determine whats what...
Firstly, with set unplugged, use your meter to check the fuses on Y-SUS and Z-SUS. Any blown and there's a short somewhere....
Then check the resistance from each fuse--to chassis metalwork. This should initially 'kick' or read for say half a second as the caps charge, then read a pretty high resistance.Last edited by Alastair E; 03-09-2014, 03:33 PM.TELEFIX
they are all ok checked them earlier (fuses), i disconnected the boards y-sus z-sus one at a time to see if it turned on still nothingLast edited by joehezzer; 03-09-2014, 03:37 PM.Comment
OK--Thats one of the 5V lines--there's usually a few. Some will be powered, some not when in standby.
Check 'em all, post results and the names/references of 'em pref with a pic of the plug you measured them at...TELEFIX
i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... pricelessLast edited by wills123; 03-10-2014, 05:05 PM.Comment
by dicky96Hi guys
I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby... -
by FailengHello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing... -
by mburke26219Hi All,
Currently struggling with this bios and EC Problem and hope someone with more knowledge might be able to help, so my laptop PC Specialist Ionico 17 ( Tongfang GM7TGxP / 11800h rtx 3070 ) had lower than normal resistance on the PCH, so before i changed the pch i attempted to flash a bios/ec from same type of laptop board ( i am not the original owner and PC Specialist would not help ) which did flash ok but no change, after that i changed the chip and all resistance readings from all rails were normal, so i turned the laptop on with the new PCH and it turned on as soon as i...-
Struggling to identify this component.
I thought it might be an Linear Regulator but the pins in the circuit don’t seem to correspond
Many thanks1 Photo -
by eurgencaHello.
I am struggling with EGT LED monitor. Panel is made from AUO.
I have 1/4 good and 3/4 bad pictures like you can see from the pic.
So far I checked power supply and it is ok. I cleaned connection from panel to LVDS and LVDS to digital board. No luck.
What is the problem with this LCD?
Pannel, LVDS or digital board. I have no idea so please help me someone.
Regards, Sebastijan....-
07-26-2025, 06:10 AM -
- Loading...
