Sony KDL-46S2530 Sound & No Picture.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: Sony KDL-46S2530 Sound & No Picture.
    sorry to sound like a noob vincegregor69 but how do i know what the rating is ? would i just be best off buying a new one as there only £8 from ebay ?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5036
      • New Zealand
      I believe the fuse should have its rating marked on it somewhere.
      -David VanHorn
        type P 3A/32V 0603 format.
        http://cpc.farnell.com/multicomp/mc0...20This%20Range
        min order 10 for £1.90 plus VAT, free delivery
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          Tom66 i removed a fuse from a T-Con board T370XW02 V5 and soldered it onto the board and it switched picture on absolutely no problem ? should i leave that one on or replace with correct one ?
            You should replace it with a new, correct type for continued safe operation.
            Actually probably better to use these
            as TIME DELAY is less likely to randomly blow.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              #26
              thanks tom will order some and get it swapped out. cheers
              • iglitare
                by iglitare
                09-04-2025, 07:13 AM
              • DKWS89
                Sony XBR 49x900E - Sound and backlight on but no picture
                by DKWS89
                Hey Guys,
                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                12-14-2023, 04:30 PM
              • KYBOSH
                Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                by KYBOSH
                Previous owner said TV just went blank one day.
                They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                I just downloaded the Sony KD-75X7800F Service Manual and...
                11-19-2024, 10:12 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
