Vizio LDO Voltage Reg VW42LHDTV10A
  • Ltank
    • Jun 2013
    • 776
    Well I read up allthe other post on the site. The Yellow standby light comes on and then turns white when turned on but no 12 or 24vdc. The main board is 3642-0262-0150. I checked the LDO and other voltage regulators.
    U2 5.12 3.31 2.07
    U8 5.12 3.28 2.05
    U33 5.12 3.32 2.07
    U7 3.32 1.11 .02 ---- Bad output and is the input voltage correct?
    U9 3.32 1.51 .001---- Is the input voltage correct?
    U3 12.03 5.06 .00
    U10 5.11 1.38 2.63
    I can turn on Power Supply by jumping PS-0n with 1kohm jumper to 5vdc
    Does anyone have a list of what LDO controls what functions? Thereis lots of info on checking the LDO. What is the proper sequence of checking them?
    Replacing U7 will let the PS turn on? or U7 and U9?
    Re: Vizio LDO Voltage Reg VW42LHDTV10A
    U7 3.32 1.11 .02 ---- Bad output and is the input voltage correct?, .02 +1.25Vref = 1.27V, so it is bad.
    U9 3.32 1.51 .001---- Is the input voltage correct. 3.32V is enough input voltage for the LDO to operate. This one may be 1.5V fixed LDO. What is the number printed on the body?
    I believe the output of U33 feeds the input of U7 and U9, you can trace that out.
    • Ltank
      • Jun 2013
      • 776
      Well I replaces U7 a 1117 adjustable LDO and the set came to life. Set works fine I turned on/off several times and has played several hours. The mainboard wad not sending the PS-on to the SMPS. Set mow works after replacing U7. Nothing else was replaced so I assume U7 supplies the voltage for the PS-on command
        Glad to hear it working now.
        • Derrick8265
          • Dec 2015
          • 17
          Re: FIXED...Vizio LDO Voltage Reg U7 VW42LHDTV10A
          Bud -
          You asked me to follow-up on my Vizio 42" regulator (U7) repair:..
          A few weeks ago, you helped me identify the correct voltages for my Main-Board Regulators in my VW42LHDTV10A. You posted the links to the Digi-Key Regulators I needed, mainly U7. I ordered them and replaced U7 only...and IT POWERED ON IMMEDIATELY! So, Thank you for your help!
          I can not find in this forum where I was posting before, so I followed up here since this thread is about the same problem and solution.
          My symptoms were logo glows orange, but nothing else is responsive.
          We tried replacing the PSU first (before joining this site), but that produced no changes. So, now I have a good spare PSU sitting around in a box. Oh well, at least the regs were cheap!
          In the end, it only cost about .45 cents to repair a TV that I intercepted on its way to the dump. I learned a bunch from this experience, and am now prepared for other regs that might go bad too, because I ordered U33, U2, U9, U8, etc...when I was placing the order.
          Thanks again!
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • DXseekerMO
            Vizio E400i-B2 missing stand-by voltage
            by DXseekerMO
            I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
            So I took some voltage readings upon the original board. Here's what I found:
            Main caps have 169.9v
            AC detect voltage is 1.3v
            None of the MOSFETS appear to be short.
            The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
            10-30-2021, 10:19 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
