Westinghouse VR-3215 loud hum
  • soothsayer
    • Mar 2014
    • 6
    I'm getting a loud hum with my audio on my Westinghouse VR-3215 (checked 3 inputs, all hum). I looked at the power supply board but didn't see any crowned or leaking caps. Any suggestions on where to look......
    Just found this on fixya-
    "I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again."
    http://www.fixya.com/support/t121565...supply_vr_3215
    Good advice?
  • Ltank
    • Jun 2013
    • 776
    Re: Westinghouse VR-3215 loud hum
    Hum can be from two sources. Either the audio/speaker circuits or the baklight transformers if set is LCD TV.
    If there is a load on transformers due to a bad tube or a capacitor in circuit making it too low a frequency oscilate.
    If its audio it can be the main board or the audio source. Try a different audio. is it on all audio inputs?
    • soothsayer
      • Mar 2014
      • 6
      It's on all inputs. As soon as it get power the hum starts even with the volume all the way down. It does not go up and down with volume, it stays constant.
      • Ltank
        • Jun 2013
        • 776
        Most likely the power supply or inverter. What ET tools and meters do you have? If limited then i suggest buying a new board. I did not find any info on this set so, I dont know if the inverter is part of the power supply or seperate. Possable that a backlight tube could be loading supply. It thats the case another
        power supply would do the same thing. Make noise.
        • soothsayer
          • Mar 2014
          • 6
          This looks like my power supply -
          http://www.coppelltvrepair.com/p/375...it-for-old-dud
          • aidanmo
            Philips 43PUS7506/12 - Loud blown out sound
            by aidanmo
            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
            I thought maybe the speakers got damaged, so I replaced them - no dice.
            • Using the internal speakers, it always happens.
            • Using the headphone jack, it never happens.
            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
            02-28-2025, 03:13 PM
          • alro7779
            Westinghouse WD32HN1640-S black screen-no backlight, mainboard TP.MS3393.PB818
            by alro7779
            Hello, guys!
            I have this Westinghouse 32" LCD TV that turns on, standby led lights up (blue) but no image. If I knock on the screen there's no backlight present. I took the back cover off and injected voltage on the led connector using a Led TV Backlight Tester, and no light at all, so... it must be that there's some bad Leds, right? Or there is some another testing that should I have to do? Any guiding I'll appreciate it very much. Thanks in advance!
            Alex....
            10-03-2025, 05:49 PM
          • mon2
            Crate guitar amp with extremely loud static on power on (no input)
            by mon2
            Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
            07-18-2025, 06:40 AM
          • justice171
            Lenovo E15 Gen 2 Keeps Beeping Loud Noise
            by justice171
            Hello Badcaps Members,
            I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
            I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
            When I use Lenovo PC Diagnostics App I get results as 01000
            Here are the details:
            • Model: Lenovo ThinkPad E15 Gen 2
            • Board Numbe
            10-01-2024, 09:19 PM
          • eliemgh
            lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
            by eliemgh
            lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
            09-27-2024, 02:40 AM
