TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
    replied
    Towards the bottom they have options, one says get more help-amazon support, boy howdy there's nothing like trying to go thru 2 entities to get one piece of firmware or do you need more? I noticed it's there but not clickable on that screen, lol=nightmare https://support.tcl.com/troubleshoot...arch=156097362
    replied
    So what's up with this being a new tv but no firmware easily available from the tcl website. Are they the sort of weirdos that want you to contact them personally to get the firmware or sum such?
  • Diah
    replied
    Naah... nothing on the display.
    LOL... you are swimming at opposite my direction..
    please read the specs of yours soc T962 for example to know how communicated or try its second boot to have screen on.
    rebrand it with other brand LOL you have the tools like this TVs all used the Soc Xiaomi Mi TV 4 Pro 4A 32"/43" (India) / Skyworth G6A / TCL P4
  • CapLeaker
    replied
    Originally posted by Diah
    do please as post 106
  • Diah
    replied
    I already tried to disconnect the ribbon cables. With only one from either side connected / disconnected, both on and both off. That doesn't do squat.
    Yeah... firmware... sure! If I could find it, I would have flashed the shit out of the TV already.
    i am talking on U ribbon which they are at the middle of each side not the LVDS..... now yours MB working and booting complete and pick IP.. need to try now at this stage.. dont histaed
  • CapLeaker
    replied
    yours TV starting and of sure you have now the audio optic lit red.. and you can hear sound too if there are source.... but now we have the Soc GPU cutting off for some reason
    one i described about the Kernel...
    second they are load.. so if all above post didn't work for you.. to bring recovery on..
    try remove the rest of the back cover to have access to panel buffer boards... and from there we reduce the load by disconnecting the U ribbon cable at each half a time or both side together...
    if this didn't bring little part of screen on... then stop and try to find firmware to write it again...
  • Diah
    replied
    Had to put a network switch in here to do all that. O.k. here is what happened:
    The exact thing than last time and still nothing on the screen.
    I did plug the TV into my network and my switch started blinking. I did an IP scan and the main board does pull an IP address.
    I don't think I can change the HDMI, since I can't see anything, unless it is switching automatically to the HDMI port in use.
  • CapLeaker
    replied
    the android on the stick mean the TV start and booted and sync the usb stick so it write data of android on it.. good sign, it mean also if you fed it with HDMI signal and do change the source you will hear sound
    try this
    1- dont rezise the stick keep it in full format Fat32 and put the file on it then try..the same way
    2- with out stick in USB port if you press power and keep pressing then plug it in wall the Amlogic will call the recovery hope screen come on
    3- with out any things as it sart and USB stick blinking... mean it start.. plug the TV with LAN cable to yours router.... log in yours router and check the TV IP... we may use it by using ADB on PC to reboot the TV in recovery
  • Diah
    replied
  • Diah
    replied
    Unplugged the TV again for 20seconds, plugged the TV in while keeping the power depressed until it rebooted. Then the USB drive started blinking, so I let it finish.
    Unfortunately I didn't see anything on the screen.
    Here is what I got out on the USB:
    So... this thing is listening on the USB, but I have to see something on the screen yet.
    try this
  • CapLeaker
    replied
    try this... plug out the TV from wall copy the file after extract the zip factory_update_param.aml on root USB stick formated Fat32 or Fat not bigger than 2Gb.. insert first at USB 1 then press power on the TV keep press while you plug the TV in wall... for at least 5-7 second... hope your screen will come on say no data for update but it will wipe the rest in command i wrote in the script.
    you may try all USB ports one by one for several time as we dont know which on the Amlogic boot related to USB ports
    I did this step first:
    Took a 4GB USB flash drive and resized it to 1.6GB, formatted it with FAT32 and copied this .aml file to root.
    Reassembled the main board and put a new heat pad on it.
    Plugged in the USB drive (only one USB on this thing), Pressed the power button and plugged the TV in and kept pressing for 7 seconds. Nothing happened.
  • CapLeaker
    replied
    you are lucky as the Soc Amlogic.. it had bootloader section on it which we can trick it with PC..connect yours TV with male to male USB with PC let see how the PC show
    here we are with tools
    Oyyy... I got to set this up. stby...
    replied
    It's getting interesting
  • Diah
    replied
  • Diah
    replied
    Thanks for post 91. That was helpful to understand why there is no 12V going directly to the panel. Never thought of it that way. The Soc is an Amilogic. So now I am out of clue. The Mstar I know, but this Amilogic thing… nope.
  • CapLeaker
    replied
    Thanks Diah, I thought that should be the case, they make it pretty tough for the non-tech inclined like some seniors for example AND me.
    I should set this post as it being the answer.
  • CapLeaker
    replied
    no need to be online to receive antenna or cable or sat.... but the set should be activated first with user profile
    I didn’t get that far. I turned it on and worked, Connected cables to it including Ethernet. Then it said new firmware found and it did its thing. So I left the room for 10mins. Came back and found the TV in this state, Nobody touched it in between.
  • CapLeaker
    replied
    he need to take out the heatsink of the Soc and tell the name of the Soc. if its MSTAR... so the tools will help flashing
    replied
  • Diah
    replied
    These fire tvs are way too dependent on being online, what if someone just wanted to hook up an antenna and watch over the air non-compressed programs like the person in the LG thread, is it even possible without being online?
  • Verlengsnoer
    Bios splash/logo change
    by Verlengsnoer
    at firs, i hope this is the right place to post my question.
    Im looking for a tool to change the bios logo.
    everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
    i know that HP has a build in option to change the splash logo.
    but i want to change the manufacturer logo to an own logo.
    I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
    10-28-2022, 09:52 AM
  • Echoo
    Fujitsu D757 sff desktop pc bios logo reset
    by Echoo
    Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
    11-25-2024, 01:54 AM
  • smarty
    Can anyone identify PCB logo?
    by smarty
    Can anyone identify logo shown below?
    The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
    I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
    Neither ChatGPT nor Copilot know the correct answer.
    TIA
    09-10-2024, 11:48 PM
  • q2v5
    Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
    by q2v5
    Lenovo T480s
    Model 20L8-S3TE00
    Board ET481-U10
    Chip MX25L12873F
    Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
    2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
    The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
    08-15-2024, 10:40 PM
  • p.puhakka
    Fujitsu Esprimo K557/24 allinone desktop, boot logo
    by p.puhakka
    Hello forum!
    I have received a lot of help here, regarding bios modding. Very thankful!
    Now I have a lot of Fujitsu K557 desktops, and those have custom bios logo/custom splash screen, and I need to change them to the original Fujitsu logo.
    I am looking for the easiest way, because I have about 40pcs of them, and I think there is some "official" way to do this.
    I have tried a lot of Fujitsu tools, which can inject the logo to the bios file, but no luck.
    Any suggestions? Thanks!
    06-06-2024, 11:24 AM
