Hitachi 40HYC42
  • dragometin
    • Aug 2016
    • 20
    • France
    Hitachi 40HYC42
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595 -> βΈ® keypad_pressed is [0]
    12:24:06.666 ->  ir_pressed is [0]
    12:24:06.666 -> check_sw_upgrade
    12:24:06.666 -> no OAD Flag
    12:24:06.666 -> no need to start factory usb download
    12:24:06.666 ->
    12:24:06.666 ->  #* 4. NAND is already programmed (not Empty) ***
    12:24:06.666 -> Hit any key to stop autoboot:  0
    12:24:06.666 -> ------>update_default_env, idx = 4
    12:24:06.666 -> ------>bootargs_default = console=ttyS0,115200 quiet lpj=831488 ubi.mtd=1 ubi.mtd=2,2048 root=ubi1:RFS rootfstype=ubifs ro EMAC_MEM=0x200000 DRAM_LEN=0x20000000 LX_MEM=0x06FF0000 LX_MEM2=0x65C62000,0xA300000
    12:24:06.700 -> ------>mtdparts_default = mtdparts=edb64M-nand:5m(KL),16000k(CONF),114m(UBIA),123264k(UBIB),-(NA)
    12:24:06.700 -> PWM_MAX / MIN = 255 / 23
    12:24:06.700 -> IsBootLogoScalingUp, scalingUp = 0xFF !
    12:24:06.700 -> bootlog doing scaling up...>>>
    12:24:06.700 -> Boot Logo Resolution = 712 x 400
    12:24:06.700 -> SPI_BOOT_LOGO_ADDR = 0x120000
    12:24:06.870 -> PWM_MAX / MIN = 255 / 23
    12:24:06.870 -> MDrv_PNL_Init u32PnlRiuBaseAddr = BF200000
    12:24:06.870 -> MDrv_PNL_Init u32PMRiuBaseAddr = BF000000
    12:24:06.870 -> LVDS Swing = 300
    12:24:06.870 -> GE_SetOnePixelMode
    12:24:07.514 -> UnProtect MIU block 0 : 0x75F1000 0x76C6000
    12:24:07.514 ->
    12:24:07.514 -> NAND read: device 0 offset 0x0, size 0x500000
    12:24:07.514 ->
    12:24:07.852 ->
    Reading data from 0x0x -- 100% complete.
    12:24:07.852 ->  5242880 bytes read: OK
    12:24:08.090 -> [0;34m*******************************[0m
    12:24:08.090 -> [0;34m* Kernel Authentication SUCCESS !! *[0m
    12:24:08.090 -> partition_num=3
    12:24:08.090 -> 0x014A0000-0x086A0000 : "mtd=2"
    12:24:08.328 -> =========================
    12:24:08.328 -> RootFs's Size : 0x155000
    12:24:08.328 -> RootFs's offset : 0x0
    12:24:08.328 -> RootFs's offset : 0x155000
    12:24:08.362 -> RootFs's offset : 0x2AA000
    12:24:08.362 -> =========================
    12:24:08.362 -> RootFs's Size : 0x155000
    12:24:08.362 -> RootFs's offset : 0x3FF000
    12:24:08.362 -> BAK:RootFs's Size : 0x155000
    12:24:08.362 -> Volume RFS found at volume id 1
    12:24:08.362 -> read 1396736 bytes from volume 1 to 84000000(buf address)
    12:24:08.566 -> [0;34m*****************************[0m
    12:24:08.566 -> [0;34m* Rootfs Authentication SUCCESS !! *[0m
    12:24:08.566 -> =========================
    12:24:08.600 -> RootFs's Size : 0x155000
    12:24:08.600 -> RootFs's offset : 0x554000
    12:24:08.600 -> =========================
    12:24:08.600 -> RootFs's offset : 0x6A9000
    12:24:08.600 -> RootFs's offset : 0x7FE000
    12:24:08.600 -> RootFs's offset : 0x953000
    12:24:08.634 -> Volume VEN found at volume id 2
    12:24:08.634 -> read 9951744 bytes from volume 2 to 84000000(buf address)
    12:24:09.550 -> [0;34m*****************************[0m
    12:24:09.550 -> [0;34m* VEN Authentication SUCCESS !! *[0m
    12:24:09.584 -> ## Booting image at 81000000 ...
    12:24:09.584 ->    Image Name:   Linux-2.6.28.10-CL677690-mstar
    12:24:09.584 ->    Created:      2014-05-22   5:02:26 UTC
    12:24:09.584 ->    Image Type:   MIPS Linux Kernel Image (uncompressed)
    12:24:09.584 ->    Data Size:    3531396 Bytes =  3.4 MB
    12:24:09.584 ->    Load Address: 80200000
    12:24:09.584 ->    Entry Point:  80204150
    12:24:09.652 -> OK
    12:24:09.652 ->
    12:24:09.652 -> Starting kernel ...
    12:24:09.652 ->
    12:24:09.652 -> >>CMD:93,8,1,0,0,0,0
    12:24:09.652 ->
    12:24:09.652 -> MDrv_Ursa_6M30_3D_Cmd write data fail.....
    12:24:09.652 -> sellect lvds on/off error!!!
    12:24:12.266 -> Control BacklightDim with GPIO
    12:24:12.266 -> MDrv_Ursa_PNL_ON...
    12:24:12.266 -> Hello UART
    12:24:12.266 ->
    [ERROR] PIU UART1 Init Failed
    12:24:12.844 ->
    init started: BusyBox v1.14.1 (2013-10-09 22:32:32 CST)
    12:24:12.878 ->
    starting pid 249, tty '': '/etc/init.d/rcS'
    12:24:12.912 -> mount: no /etc/mtab
    12:24:12.946 -> mount: no /etc/mtab
    12:24:12.946 -> mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
    12:24:12.946 -> Mounting conf
    12:24:13.014 -> mount: no /etc/mtab
    12:24:13.014 -> Mounting vendor
    12:24:13.048 -> mount: no /etc/mtab
    12:24:13.048 -> Mounting var
    12:24:13.082 -> mount: no /etc/mtab
    12:24:13.082 -> Mounting tmp
    12:24:13.082 -> ifconfig: SIOCSIFADDR: Invalid argument
    12:24:13.116 -> ln: /vendor/lib/utopia/lib: Read-only file system
    12:24:13.116 -> NO IP tuner - NOT Starting Telnetd Service, External Watchdog, Dhcp Client, Bootcaster Client And Thttpd Server...
    12:24:13.726 -> Debug(drm): assert,log
    12:24:13.997 -> [MSOS_PRINT][000567]     pthread_mutex_init
    12:24:13.997 -> [MSOS_PRINT][000569]     CHIP_InitISR
    12:24:13.997 -> Flash is detected (0x0507, 0xC2, 0x20, 0x15)
    12:24:14.065 -> SPI 02M
    12:24:14.065 -> [1;35m MBootVer = 02M-339_1.6S95M [0m
    12:24:14.065 -> [1;35m Get [M-], VerNum = 339[0m
    12:24:14.065 -> [1;35m MBootVer = 339, 260 ---> [0m
    12:24:14.065 -> [0;31m[ICE_InitialiseSystemMemory, 152]MMAP from SPI:4[m
    12:24:14.099 -> [0mNo Netflix
    12:24:14.099 ->   [000]                                MMAP_AEON_MEM0x0, 0x200000, 0
    12:24:14.133 ->   [001]                                  MMAP_LX_MEM0x200000, 0x6ff0000, 0
    12:24:14.133 ->   [002]                             MMAP_EMAC_BUFFER0x71f0000, 0x200000, 0
    12:24:14.133 ->   [003]                              MMAP_PM_PROGRAM0x73f0000, 0x10000, 65536
    12:24:14.133 ->   [004]                                 MMAP_MAD_MEM0x7400000, 0x31c000, 4096
    12:24:14.133 ->   [005]                           MMAP_MAD_SE_BUFFER0x7400000, 0x11c000, 4096
    12:24:14.167 ->   [006]                          MMAP_MAD_DEC_BUFFER0x751c000, 0x200000, 4096
    12:24:14.167 ->   [007]                           MMAP_MMPLAYER_POOL0x771c000, 0x2710000, 4096
    12:24:14.167 ->   [008]                                 MMAP_3D_COMB0x771c000, 0x700000, 4096
    12:24:14.167 ->   [009]                             MMAP_SECTION_MEM0x7e1c000, 0x200000, 8
    12:24:14.167 ->   [010]                                 MMAP_VBI_BUF0x801c000, 0x10000, 8
    12:24:14.201 ->   [011]                           MMAP_PVR_DUMMY_BUF0x802c000, 0x200000, 8
    12:24:14.201 ->   [012]                              MMAP_TPDATA_MEM0x822c000, 0x82000, 4096
    12:24:14.201 ->   [013]                      MMAP_VE_FRAMEBUFFER_ADR0x82ae000, 0x195000, 8
    12:24:14.201 ->   [014]                           MMAP_TSP_VQ_BUFFER0x8443000, 0x100000, 8
    12:24:14.201 ->   [015]                     MMAP_PVR_DOWNLOAD_BUFFER0x771c000, 0x480000, 4096
    12:24:14.235 ->   [016]                       MMAP_PVR_UPLOAD_BUFFER0x7b9c000, 0x240000, 4096
    12:24:14.235 ->   [017]                     MMAP_PHOTO_SHARE_MEM_ADR0x771c000, 0x400, 16
    12:24:14.235 ->   [018]                        MMAP_MAD_JPEG_OUT_ADR0x771c400, 0x1000000, 16
    12:24:14.235 ->   [019]                   MMAP_MAD_JPEG_READBUFF_ADR0x871c400, 0x100000, 16
    12:24:14.235 ->   [020]                  MMAP_MAD_JPEG_INTERBUFF_ADR0x881c400, 0x600000, 16
    12:24:14.269 ->   [021]                    MMAP_MAD_JPEG_DISPLAY_ADR0x8e1c400, 0x1000000, 16
    12:24:14.269 ->   [022]                           MMAP_VDPLAYER_DATA0x771c000, 0x500000, 4096
    12:24:14.269 ->   [023]             MMAP_VDPLAYER_BITSTREAM_BUFF_EXT0x7c1c000, 0x500000, 0
    12:24:14.269 ->   [024]                 MMAP_VDPLAYER_BITSTREAM_BUFF0x811c000, 0x400000, 0
    12:24:14.269 ->   [025]        MMAP_VDPLAYER_SUBTITLE_BITSTREAM_BUFF0x851c000, 0x80000, 0
    12:24:14.303 ->   [026]                     MMAP_MP4_SUBTITLE_BUFFER0x859c000, 0x80000, 4096
    12:24:14.303 ->   [027]                        MMAP_MP4_SUBTITLE_TAG0x861c000, 0x10000, 4096
    12:24:14.303 ->   [028]                          MMAP_SCALER_DNR_BUF0x9e2c000, 0x1815000, 4096
    12:24:14.303 ->   [029]                           MMAP_MP3_INFO_READ0xb641000, 0x1000, 4096
    12:24:14.303 ->   [030]                                 MMAP_M4A_BUF0xb642000, 0x4000, 4096
    12:24:14.337 ->   [031]                                MMAP_M4A_STCO0xb646000, 0x18000, 4096
    12:24:14.337 ->   [032]                               MMAP_IRKEY_BUF0xb65e000, 0x400, 4096
    12:24:14.337 ->   [033]                               MMAP_MIU1_POOL0xb65f000, 0x600000, 4096
    12:24:14.337 ->   [034]              MMAP_VDPLAYER_BMP_SUBTITLE_BUFF0xbc5f000, 0x380000, 0
    12:24:14.337 ->   [035]                                MMAP_XC_MLOAD0xbfdf000, 0x1000, 1
    12:24:14.371 ->   [036]                             MMAP_2D3D_DD_BUF0xbfe0000, 0x100000, 1
    12:24:14.371 ->   [037]                             MMAP_2D3D_DR_BUF0xc0e0000, 0x100000, 1
    12:24:14.371 ->   [038]                         MMAP_SCALER_DNR_BUF20xc1e0000, 0x1815000, 4096
    12:24:14.371 ->   [039]                                MMAP_MIU0_END0xd9f5000, 0x0, 1
    12:24:14.371 ->   [040]                               MMAP_VDEC_CODE0x20000000, 0x100000, 0
    12:24:14.405 ->   [041]                        MMAP_VDEC_FRAMEBUFFER0x20100000, 0x1e00000, 0
    12:24:14.405 ->   [042]                          MMAP_VDEC_BITSTREAM0x21f00000, 0x600000, 0
    12:24:14.405 ->   [043]                                MMAP_OSD_MENU0x22500000, 0x375f000, 4096
    12:24:14.405 ->   [044]                                MMAP_OSD_MISC0x25c5f000, 0x2000, 4096
    12:24:14.405 ->   [045]                               MMAP_XC_MLOAD10x25c61000, 0x1000, 0
    12:24:14.439 ->   [046]                                 MMAP_LX2_MEM0x25c62000, 0xa300000, 0
    12:24:14.439 -> [1;33m[mapi_MemoryInit, 192]u8MMAP = 4, u32MIU0End = 0xd9f5000, u32MIU1End = 0x5c62000
    12:24:14.439 -> [0mmem_type: 0, phy_addr = 0xb65f000, start_addr = 0x50edb000, size = 6291456
    12:24:14.439 -> mem_type: 1, phy_addr = 0xbc5f000, start_addr = 0x3de7f000, size = 0
    12:24:14.473 -> ******* ICE_LoadProfileData - Enter
    12:24:14.473 -> Load profile /conf/mb95_hwprofile.bin
    12:24:14.473 -> ******* ICE_LoadProfileData - Exit
    12:24:14.473 -> Load profile /conf/mb95_swprofile.bin
    12:24:14.507 -> ******* ICE_LoadProfileData - Exit
    12:24:14.507 -> FROST_DebugStartConsole !
    12:24:14.507 -> Terminal: vt102
    12:24:14.507 -> terminal ready
    12:24:14.507 ->
    12:24:14.507 -> #*### Console Started ###
    12:24:14.575 -> CheckForTheFirstTime file open error
    12:24:14.575 -> **** ICE_HardwareInit ****
    12:24:14.575 ->
    12:24:14.575 -> Try loading bin panel file
    12:24:14.575 -> Read : 28888 target: 28888
    12:24:14.609 ->  No need to update IR Flag
    12:24:14.609 -> ----> Rc type: RC5
    12:24:14.609 ->
    12:24:14.609 -> TUNER : Si2157      EXTENSION : NONE
    12:24:14.609 -> Load country file
    12:24:14.609 -> HASHKEY[0xd] DIVX[0x0] CONNECTIVITY[0x1] VC1[0x1] SRS[0x0] MPEG4[0x1]
    12:24:14.609 -> [1;33m<< CHIP = D8_PRIME, PROJECT = THORIUM_MB90, Customer_Hash = 1 >> [0m
    12:24:14.643 -> Auth OK
    12:24:14.643 ->
    12:24:14.643 -> frost_debug >>> testtool socket: server creation
    12:24:14.643 -> ----> logo backlight off
    12:24:14.643 -> Read MMAP from SPI:4 from Profile:4
    12:24:14.643 -> Read Netflix Enabled from SPI:0 from Profile:0
    12:24:14.643 -> ----> additional delay for logo backlight off = 0(ms), loop:0
    12:24:14.643 -> Init PWM2
    12:24:14.677 ->
    12:24:14.677 -> frost_debug >>> testtool socket: server bind is successfull
    12:24:14.677 ->
    12:24:14.677 -> ICE_LowPowerModeForceStandby(): exit_type[0] - fti_completed[1] - hotel_powerup[2] - profile_powerup[1] - last_state_standby[0]
    12:24:14.677 -> [AP]mapi_pm_IlluminatedLogoFadingOn = 1
    12:24:14.677 ->
    12:24:14.677 -> frost_debug >>> testtool socket: server listen is successfull
    12:24:14.881 -> Base = 0x2ad44000
    12:24:14.881 -> ----> additional delay for logo off sequence = 194(ms), loop:16
    12:24:14.881 -> ----> delete logo off thread
    12:24:14.915 -> MApi_XC_Sys_Init 24->60Hz
    12:24:14.915 -> _MApi_XC_Sys_Init_Panel
    12:24:14.915 -> MDrv_PNL_Init u32PnlRiuBaseAddr = 2ad44000
    12:24:14.915 -> MDrv_PNL_Init u32PMRiuBaseAddr = 2aac4000
    12:24:14.915 -> [XC,Version][0;36m
    12:24:15.050 ->  [m[0;31m[mapi_HardwareReadBin, 262] ASSERT, hwid = 16
    12:24:15.084 -> [0mFROST_ASSERT: ice_product_mstar/mstar/mapi/mapi_hardware.c mapi_HardwareReadBin 263
    12:24:15.084 -> [_MApi_XC_Sys_Init_PQ, 816] PQ_TEXT_BIN_STD_SUB NG
    12:24:15.084 -> TextBinStartaDDR ID0=328ae70
    12:24:15.084 -> BinStartaDDR ID0=2b07c008
    12:24:15.084 -> BinStartaDDR ID2=328fe78
    12:24:15.084 -> BinStartaDDR ID1=2b0e8008
    12:24:15.118 -> Found new edid file in file system
    12:24:15.118 -> [1;35mMMAP_XC_MLOAD1, Phy_Adr = 0x25c61000, Size = 4096[0m
    12:24:15.118 -> jason mapi_pad_init
    12:24:15.118 -> [1;33m Pad_Init D8P [0m
    12:24:15.424 -> [1;33m[msKeypad_Init, 264]Init Key pad for MB9X!!!
    12:24:15.458 -> [0mOpen IIC Kernal Module Success!
    12:24:15.458 -> ~~~~mapi_I2cRead fail ~~~~~~s32WCountIIC=-1
    12:24:15.492 -> ~~~~mapi_I2cRead fail ~~~~~~s32WCountIIC=-1
    12:24:15.492 -> ~~~~mapi_I2cWrite fail ~~~~~~s32WCountIIC=-1(u8ChIIC=0x1, u8SlaveIdIIC=0xB4)
    12:24:15.560 ->
    12:24:15.560 -> Read ERROR...
    12:24:15.628 ->
    12:24:15.628 -> Read ERROR...
    12:24:15.628 -> clock_firmware: 0:: tas_Status: 0
    12:24:15.628 -> Init GFX...
    12:24:15.628 -> GE_SetOnePixelMode
    12:24:15.628 -> GFX lib version: GFX_191700608062
    12:24:15.628 ->
    12:24:15.628 -> PoolAlloc(mtype, addr, size, used_size) = (0, 0x512faff0,1966080,1966080 )
    12:24:15.628 -> Init OSD Plane... H: 1080, W: 1920, HStr: 112
    12:24:15.662 -> GOP Addr: 22500000, 0375f000, 25c5f000, 00002000
    12:24:15.662 -> ====================
    12:24:15.662 -> First GOP driver instance, flush GWIN HW
    12:24:15.662 ->
    12:24:15.662 -> [GFlip (Driver)][00545] GLIP device not opened!!!!
    12:24:15.696 -> [GFlip (Driver)][00545] GLIP device not opened!!!!
    12:24:15.696 ->
    12:24:15.696 -> [GOP_ALL][Driver Version]: 0087, BuildNum: 0017, ChangeList: 00608254
    12:24:15.696 -> GOP lib version: GOP_871700608254
    12:24:15.696 ->
    12:24:15.696 -> End GOP init
    12:24:15.696 -> jason u8KeyData==ffff
    12:24:15.730 -> **** Early ICE_AudioInit successful !!!
    12:24:15.730 -> Tas5719 is available
    12:24:15.730 -> *****romid  80/0x50
    12:24:15.730 -> sil2157 firmware
    12:24:15.764 -> DSP code loaded successfully
    12:24:15.764 -> MApi_AUDIO_SetSystemInfo() : Warning! g_AudioVars should not be NULL !!!
    12:24:15.798 -> MApi_AUDIO_SetSystemInfo() : Perform SHM Init here !!!
    12:24:15.798 -> [HAL_TSP_CPU_SetBase][2062] load firmware (address, size) = (0x07e1c000, 0x0000281c)
    12:24:15.832 -> firmware 111 0x07e1c000 0x00000007 0x0000e1c0
    12:24:15.866 -> init Shared
    12:24:15.900 -> ------------------> mdev_CofdmDisableTSPAD
    12:24:15.934 -> Init SILABS_SI2158(Cust tuner)
    12:24:16.002 -> [MFC_ONEBIN] MFC FW version must >= v5.6
    12:24:16.002 -> [0;32m[Check_DFB_MMAP_Update, 787]Netflix disable, Skip check DFB mmap
    12:24:16.002 -> [0m[1;33m[CheckNetflixEnableState, 917]reset_system = 0
    12:24:16.002 -> [0m~~~~mapi_I2cWrite fail ~~~~~~s32WCountIIC=-1(u8ChIIC=0x1, u8SlaveIdIIC=0xB4)
    12:24:16.036 -> ~~~~mapi_I2cWrite fail ~~~~~~s32WCountIIC=-1(u8ChIIC=0x1, u8SlaveIdIIC=0xB4)
    12:24:16.036 -> ----> MonitorVoltageDropTaskCreate: priority:0, peroid:5
    12:24:16.070 -> ~~~~mapi_I2cRead fail ~~~~~~s32WCountIIC=-1
    12:24:16.070 -> (2) == MSB123x NO exist
    12:24:16.070 -> MFC is N/A
    12:24:16.070 -> [Utopia] T9 is not support
    12:24:16.104 -> HW_getMbootVersion ret 1
    12:24:16.104 -> =================================================================
    12:24:16.104 -> ## Software Version: V.3.6.2j  SVN 149272
    12:24:16.104 ->    MBoot Version:    02M-339_1.6S95M
    12:24:16.104 ->    NAND Size:        256
    12:24:16.104 ->    DDR  Freq:        1300M
    12:24:16.104 -> act ant protection
    12:24:16.104 -> ERROR: open file /vendor/config/env.bin
    12:24:16.138 -> ***** ICE_HardwareInit end *****
    12:24:16.240 -> short circuit detect
    12:24:16.240 -> [1;35m[mapi_pm_set_SPIOffsetForMCU, 229] BOOT_FROM_51 [0m
    12:24:16.240 -> force_power_down
    What "12:24:16.240 -> short circuit detect" means? It does not say where the short circuit is.
    I can dump the firmware if needed.
  • dragometin
    • Aug 2016
    • 20
    • France
    After hours of troubleshooting, I found out it's the protection being actiavted. Can someone help me understand this circuit? If I make a jumper fom 3.3V to TP7 and the TV works
    • R_J
      • 9624
      there are many variants of this power supply what are the revision numbers of the boards? 17IPS71-xx There are even changes between the same revision sometimes.
      Do you have all four voltages present to the protection circuit? and are all the components for that circuit installed?
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • jjne
        Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
        by jjne
        I have a TX NR414, well I have two actually which are both exhibiting the same issue.
        The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
        I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
        07-28-2025, 07:51 AM
      • vbogoev
        Lenovo S6000 won't turn on. Data recovery needed.
        by vbogoev
        Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
        Code:
        [PWRAP] pwrap_init_preloader
        [PWRAP] pwrap_init
        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
        [PMIC_WRAP]wrap_init pass,the return
        06-20-2023, 06:36 AM
      • Perry Babin
        Capacitors of the same make/series that consistently fail in one amplifier while they rarely fail in a different make amp
        by Perry Babin
        This is for car audio amplifiers but I doubt that matters. There are amplifiers that use the same make/series capacitor as a different manufacturer and they consistently fail in one brand. In the other they are OK. The amplifiers are from the same era. Is it possible that the heating profile used when flow-soldering the boards could be the reason for the failure? If not, any ideas on what the difference could be?
        04-03-2024, 10:40 AM
