Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
  • jjne
    • Mar 2013
    • 47
    • uk
    I have a TX NR414, well I have two actually which are both exhibiting the same issue.
    The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
    I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years ago). Transplanted my 'good' board into the bad unit. Unfortunately it seems to gave the same issue - a lower offset of 0.5v on the right speaker. Other outputs fine on both amplifiers.
    This is leading me to think that the problem is on the HDMI board but I confess the complexity of these things intimidates me.
    Has anyone seen similar with these, or have pointers as to where the issue might be coming from? I'm going to check around the DAC next, as IIRC this is on the HDMI board.
  • frankusb
    • Apr 2015
    • 111
    I would think pure audio mode would bypass the HDMI board. Does the offset go away in pure audio mode?
    • jjne
      • Mar 2013
      • 47
      • uk
      The problem is present irrespective of whether PD is enabled.
      I have to say though that I'm now thinking this has to be an analogue issue and I've just been very unlucky to be in possession of two amplifiers with very similar analogue errors. The front right signal is buffered through a DAC on the HDMI board and goes through an analogue switch, but this is buffered to the preamp board via a series 47uF cap, so surely any offset present at the digital, or DAC stages should be removed at this point right? I've checked these caps and they're fine, on both amps.
      I just find it strange to say the least if both of these units have developed the same issue on the same channel, but nowhere else.
      You'd think as well that this would trigger the protection, but it seems not.
      Unfortunately my electronics skills do not extend to being able to work out how the preamp section works - the problem surely has to be in there assuming I'm understanding the DC filter on the buffer to the main amp correctly.
      Given that the problem is consistent through all inputs I suspect that if the problem is on the HDMI board, then it's either a knackered output on the DAC, or the switch... But then why isn't this offset being filtered out pre-the preamp by the cap?
      • jjne
        • Mar 2013
        • 47
        • uk
        Think my next step is going to be trlo try to trace the offset back through the DAC, the op-amp buffer to the switch, and the switch itself. Thinking about it the offset appears when the sources are switched in - when the switch is muted the offset disappears, therefore I *think* this implies that the analogue bits after the switch are not the cause here. I'm still not sure why this isn't being filtered out down the chain but the good news I guess is if it is the DAC, the opamp buffer or the switch, I have spares of these on the bad HDMI board, so this is now a project for when I get the time to look at this properly!
        • chth96
          by chth96
          03-09-2024, 10:03 PM
        • piernov
          Reminder: rules and organization of this section
          by piernov
          Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
          I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
          Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
          This section and its subsections are about the following classes of devices:
          • Desktop computers
          • All-in-one
          03-31-2023, 06:17 AM
        • sheffieldyorky
          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
          by sheffieldyorky
          Hey there people
          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
          This is what I tried, but not in any order.
          Google
          YouTube
          BIOS
          Command Prompt (administrator privileges)
          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
          10-25-2025, 02:22 AM
        • MotherTeresa
          Onkyo TX-NR5007 (NR3007 NR1007) NAND DUMP for DZKB4 DSP
          by MotherTeresa
          Hi.
          I'm looking for a DSP NAND DUMP for the Onkyo TX-NR5007 that works with the DZKB4 chip. Can anyone help?
          Regards.
          09-20-2025, 12:09 PM
        • piernov
          by piernov
          Reminder about the rules and the organization of the "Troubleshooting Laptops, Tablets, and Mobile Devices" section.
          • Laptops
          • Phones
          • Tablets
          • Other mobile devices
          03-31-2023, 06:10 AM
