Hi everyone picked up this 75inch lg tv has sound but no picture. So far I have disconnected each lvds cable separately from the t con with no change in picture. I have looked at the boards with a thermal camera and the hottest component is the one pictured. I can’t seem to find any information on it online.
75um7050pla have backlight no sound
Suppose its a double diode, testing there, hes on a double at the 7:40 mark, meter set to diode mode: https://www.youtube.com/watch?v=0VfSvU1AHfc -
One possibility and something that should be watched out for, is maybe someone ordered the wrong mainboard. What can happen is they may order by the silkscreen numbers on the board instead of the numbers on a sticker that is usually on every board AND like our old pal Budm always stated "The silkscreen numbers are just the indicator of the board used before it is populated with other components, once it gets populated it gets the sticker which identifies the specifics of the board"Comment
Thanks, Yes quite possible, is there a way of checking the screen before I replace any of the boards?
I have disconnected the ribbon cables one at a time with no change to the display but as the above comment stated this is not the correct procedure for an LG.
We just had a thread with what seems like the same problem, he had a double diode problem, a replacement mainboard fixed the issue, mainboards are tricky and complicated, even some seasoned pros can't figure them out.Comment
show us please the U ribbon cable you tried to disconnected..!Comment
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by triplefourTCL 75S421
PSU BOARD: 40-L402H8-PWD1CG
it shows not even a flash of backlight when powering up.
but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
with mb connected, PSON... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
