Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
  • thesharpfella
    • Jul 2024
    • 3
    • Singapore
    Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4423
    • Italy - Milan
    i suppose it to be Lc-70le735x / Lc-70le735.. anyway it seems somehow a reduced vgl, maybe a tcon probem, maybe screen stripe board, disconnect tcon outputs one at a time and show the results, photo is better than video please..
    • thesharpfella
      • Jul 2024
      • 3
      • Singapore
      Thanks for the reply, Davi. I have a picture taken of the screen. This was when I switched on the power. All parts are connected here. I have not opened up the panel.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4423
        • Italy - Milan
        But the test i have suggested?
        • thesharpfella
          • Jul 2024
          • 3
          • Singapore
          Davi, I will be opening up the TV over this weekend. I will definitely get back to you with the findings.
          • TVAddict
            • Jan 2022
            • 76
            • Caribbean
            Not to insult anyone's intelligence but once saw an LG do a similar thing, unplugged it from the electrical outlet and let it sit for half hour, plugged it back in and to my surprise i had perfect picture...go figure.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4423
              • Italy - Milan
              Ma che cippa stai a di? (what do you say?)
              • TVAddict
                • Jan 2022
                • 76
                • Caribbean
                Ha! exactly..šŸ˜€
                  • 12212
                  • U.S.
                  ENGLISH is the rule here, how HARD is that to understand???
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • jonah1024
                    Sharp Aquos LC-40UG7252E LCD TV burn in?
                    by jonah1024
                    Hello!
                    I'm a few days old into this TV screens repair universe so please bear with me.
                    Recently, and all of a sudden my 40ā€ 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                    - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                    - I did a factory reset as well...
                    07-16-2024, 04:23 AM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • klassic
                    Sharp Aquos LC-60LE635E three blinks
                    by klassic
                    Hi community,
                    I will describe my problem with a TV in those short following terms to be the most precise :
                    What i have :
                    power board DPS-162KP-1
                    main logic board QPWBXF733WJN2
                    symptoms :
                    white led light logo at startup,
                    after 2 minutes, blinking 3 times a row, repeating
                    no backlight (and apparently no picture, checked panel with flashlight)
                    no startup sound
                    powerboard investigations :
                    1-2 PNL : 0v
                    3-4 GND
                    5-6-7-8 UR : 13.15v
                    9-10-11-12...
                    10-24-2023, 01:39 PM
