Sharp Aquos LC-40UG7252E LCD TV burn in?
  • jonah1024
    • Jul 2024
    • 44
    • Romania
    Hello!
    I'm a few days old into this TV screens repair universe so please bear with me.
    Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
    - I did the classic unplug and hold power button to discharge the caps but it didn't help.
    - I did a factory reset as well - no change.
    - I also started to measure some voltages from the main PSU and I get stable voltages (5v, 12v).
    - I also measured most of the labeled test pads on the scalar-T-con combo board and I get stable 1v8, 3v3, 7v and 12v.
    I tried doing the tape trick to narrow down the issue but the panel ribbon cables are soldered to the scalar/T-con board so I can't do that.
    The backlight seems to light up uniformly if I block the video signals on the LVDS cable
    I've searched online, on this forum and on a couple of electronics discord servers but I haven't found a similar issue anywhere.
    Any tips or ideas on how should go about diagnosing/fixing this?
    Thank you very very much.
    PS. The attached video shows the burning/preshipping mode I enabled to see how the defect behaves on all colors.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4327
    • Italy - Milan
    i suspect main board, must perfom the stand alone panel test,
    ​​​​​unhook lvds from main board, jumper the 12v from PSB to tcon 12v in..
    • jonah1024
      • Jul 2024
      • 44
      • Romania
      Thanks for the reply. What should I expect/ look for with the 12v jumper? 🤔 I did some measurements before and I do get stable 12v on the T-con board.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4327
        • Italy - Milan
        it"s a video test, full screen Red, green, blue, white..
        • jonah1024
          • Jul 2024
          • 44
          • Romania
          I did the video test, as shown in the video attatched while in the factory menu. Is this different? I also managed to trigger the video test while taping the LVDS in different locations and the colors look the same. If I already get 12v on the T-con why do I need the voltage bypass?
          Sorry for all the questions, I am trying to understand the process.
          Thank you!🙏
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4327
            • Italy - Milan
            there's no attachment... i don't know if it's the same, it is better as i have told, the panel if it receives power but not signals goes in to test mode, redo it and tell if it is flawless, i don't like downloading videos if possible, except streaming YouTube..
            • jonah1024
              • Jul 2024
              • 44
              • Romania
              Here is the test mode video:
              https://youtu.be/VNk8TkR7h_U
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4327
                • Italy - Milan
                OK, first this is a screen problem, MB is OK, i see there is a constant pattern, this tells me there is maybe an error in the TCON DATA, thus the content of the flash..
                if you haven't already did, udpate the TV, if the update contains TCON changements, then MB will rewrite TCON data.. in desperate case could be useful downgrade the MB soft by direct flash programming, if no go then maybe udpate it again
                • jonah1024
                  • Jul 2024
                  • 44
                  • Romania
                  Thank you!
                  I will attempt a motherboard firmware upgrade/reinstall (I’ll look online for the firmware or ask Sharp directly) then attempt a downgrade, and if that fails to fix the issue I will look for a T-con firmware and do a direct flash if possible (either jtag or desolder the rom flash).
                  I see the scaler/T-con board has a Samsung VTU63A0 display chip, two DC-DC ICs (RT6939 and RT6935) and a winbond spi flash.
                  I will document everything and be back with updates as soon as possible.
                  Thanks again! 🙏
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4327
                    • Italy - Milan
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4327
                      • Italy - Milan
                      • jonah1024
                        • Jul 2024
                        • 44
                        • Romania
                        I don’t think I got what you meant. You want me to check for short circuits between the SPI flash pins?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4327
                          • Italy - Milan
                          sorry forget this part for now..
                          • jonah1024
                            • Jul 2024
                            • 44
                            • Romania
                            [UPDATE] with new symptom:
                            I just came back after a 2 week holiday while the TV stayed unplugged for the entire time. I plugged it back to investigate the problem and there was no problem!!
                            Image was back, sharp and clear.
                            HOWEVER, after the usual ~3 min timeout it shut itself off and after I rebooted it back the image problem returned, same defect as described above.
                            Can this still be related to a software issue? My newbie gut feeling is telling me that it might be a “bad cap” somewhere?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4327
                              • Italy - Milan
                              locate the tcon flash memory, remove entirely its solder and resolder it.
                              • jonah1024
                                • Jul 2024
                                • 44
                                • Romania
                                The memory chip is a winbond 25Q16JVIG which uses I think a WSON8 socket with a big underneath ground pad and no little feet (I’ve attatched closeup pictures).
                                I don’t see any signs of bad soldering between pads and pins but I will try to reflow the solder as careful as I can to rule that out.
                                I also upgraded the NAND firmware from v4.58 to v4.68 using the usb flash but the problem did not go away. Most likely as you said it did not have to upgrade the T-con memory at all. I can’t find old firmwares unfortunately, I’ve contacted Sharp but still waiting for a reply.
                                Any other ideas?
                                Really appreciate the support!
                                Kind regards,
                                Iona
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4327
                                  • Italy - Milan
                                  Be gentle... why you say "reflow" ? my advice is different..
                                  furthermore, i see like a glue around the tcon FPGA chip (main chip), i see well? Are there any other big IC on there? Can you photograph it?
                                  • jonah1024
                                    • Jul 2024
                                    • 44
                                    • Romania
                                    I just feared I might mess things up but will add some kapton tape all around and see what I can do.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4327
                                      • Italy - Milan
                                      Ok is a difficult task, my advice, start by steps, first one, add new solder, remove it the best U can with copper braid, put new solder..
                                      • jonah1024
                                        • Jul 2024
                                        • 44
                                        • Romania
                                        Hi, I did what you said, desoldered cleaned, resoldered, The problem is still there. I also dumped the spi flash just in case.
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • sefoster
                                          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                          by sefoster
                                          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                          11-20-2022, 09:29 AM
                                        • klassic
                                          Sharp Aquos LC-60LE635E three blinks
                                          by klassic
                                          Hi community,
                                          I will describe my problem with a TV in those short following terms to be the most precise :
                                          What i have :
                                          power board DPS-162KP-1
                                          main logic board QPWBXF733WJN2
                                          symptoms :
                                          white led light logo at startup,
                                          after 2 minutes, blinking 3 times a row, repeating
                                          no backlight (and apparently no picture, checked panel with flashlight)
                                          no startup sound
                                          powerboard investigations :
                                          1-2 PNL : 0v
                                          3-4 GND
                                          5-6-7-8 UR : 13.15v
                                          9-10-11-12...
                                          10-24-2023, 01:39 PM
                                        • foxyUK
                                          Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                          by foxyUK
                                          Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                          The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                          There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                          10-22-2024, 10:27 AM
                                        • thesharpfella
                                          Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                          by thesharpfella
                                          Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                          07-23-2024, 10:37 AM
