42" Samsung pn42c450b1d Pink lines/pixels
    So I've been working on this set for a week with no luck..
    The original problem was once I turn it on, the screen only displays pink lines and pixels but there's no picture. Initially went with replacing the X-main first, but no luck, same problem.
    I found that the Y-buffer had a shorted IC. I replaced the IC and the set turns on now with a picture however the pink pixels are still there (See photos)
    I also already replaced the main board.
    What do you guys think the problem is? Since I had already replaced the X-main board. Could this be a Y-main problem?
    Re: 42" Samsung pn42c450b1d Pink lines/pixels
    Have you checked the Vs, Va, -Vsc and Ve voltages?
    Do those match sticker within 1V?
    Any Yrr/Yfr adjustment pots?
    How do the test patterns of 100% white and bar of white / block of white look?
      All the Voltages are in exact spec.
      Ve is measuring 101V
      The Y-main does have Yfr and Yrr pots. I haven't tried adjusting those yet.
      I'm not sure how to get into the test patterns. But when playing a picture with a full white screen, the entire screen is covered in pink pixels and then each pixel fades away until the entire screen is white. (however it still has a very slight pink hue to it.)
        Test patterns in service menu. From standby press Info Menu Mute Power.
        I would try adjusting the Yfr pot until the pink fade disappears on image change.
        In addition I would apply latest Samsung firmware update.
          I've noticed you replaced one buffer IC.
          Make sure you re do the silicone on the IC. It's not just for holding it on, it's electrical isolation - each one of those pins is selectively energised with 140V wrt the other pins so it's pretty critical no dirt/dust/particles of metal impringe on it.
            Turned out the Yrr pot was extremely off causing the pink pixels. I gave it a twist and all the pink pixels are now gone! The whites still look like it has a slight pink hue but I think its just my eyes or the lighting in my room...
            So I guess the initial problem was just a bad buffer IC on this one. I went through 3 buffers on ebay.. first one was the wrong model # and the other two had shorted IC's since I guess they were taken from cracked screens.. So I just replaced it on my original board.
            I've never actually seen a bad IC on these newer Samsung models though.
            Also: where can I get the silicone for the IC?
              You can use HV epoxy or any epoxy which seals without air bubbles.
              If there's a pink tinge on full white, I'd tweak the Vs up to 210~212V, common fault on these Samsung panels. That usually gets rid of pink tinge.
              I think the buffer ICs fail randomly - luckily Y-main failure doesn't kill them, and yes, most buffers from eBay appear to be bad unfortunately .
                This might work:
                MG Chemicals 1035 Non Corrosive Translucent 1-Part RTV Silione Adhesive Sealant
                Can be found on Amazon.com
                  Will this work? I can get it at an auto store. I read that someone else
                  On the forum has used it also.
                  http://www.permatex.com/products-2/p...r-82194-detail
                    Looks good - is that for ignition coils/spark plugs? If so it should work.
                      Or maybe this:
                      MG Chemicals 4226 Super Corona Dope - High Voltage Insulating Varnish
