Sky Box DSI8215 no power
  • Ralph Green
    • Feb 2013
    • 66
    Hi all.
    I have no power DSI8215. PSU FSP042-5P01. Can not see any bad caps. Someone tried to fix it by replacing caps and had no luck. Does anybody know what is a most failure with this PSU?
  • nogger
    • Aug 2010
    • 190
    Re: Sky Box DSI8215 no power
    Hi, do you have ANY voltages appearing on the secondary side ?
    Graham
      Good clear pictures of the unit and the boards?
      • nogger
        • Aug 2010
        • 190
        I used to repair these boards on a regular daily basis, used in Thomson Sky HD boxes. Check first if there's ANY voltages on the white connector (3.3 v , 6.5 v & where it says +38v you should have +24 volts (the marking on the board is incorrect).
        If totally dead then check the resistor R15 (0.33ohms) for open circuit.its in the source circuit of the FET on the silver heatsink If its open the the FET will be toast & quite likely several of the small resistors such as R21,R24 , R26 & the small diode D22.
        The mains smoother cap (C14) is a Capxon (or was unless its been changed) & they had a tendency to go open & then that would blow the FET etc.
        If the FET & R15 are intact then check the 2 1Mohm resistors R20 & R22 as they supply the start up voltage to the PWM chip, make sure they read ok through to pin 3 of the chip. I have had dry joints on these resistors before now.
        Graham
        • nogger
          • Aug 2010
          • 190
          Graham
          • Ralph Green
            • Feb 2013
            • 66
            There is voltage on the connector but is not right:
            6.5V is 2V
            3.5V is 1.4V
            14V is 7.7V
            -9V is -4.8V
            38V is 13V
            It makes a click noise as well.
            • nogger
              • Aug 2010
              • 190
              Check on the secondary side near the white plug the small diodes D90,ZD90 ,ZD91 ,D92 for s/c.(they quite often fail leading to low output) . Also, you said someone has tried changing the caps, did they change C14 (the big one) & have you confirmed that they have put the right value caps in & they haven't put a solder short anywhere ?. Post a pic of the board if you can (both sides) , maybe i can see something from that.
              Graham
                Check startup capacitor if PSU makes a click sound.
                • Ralph Green
                  • Feb 2013
                  • 66
                  I did swap startup capacitor with another one but make no different. I've checked D40, D50, D60 and Q10 all good. Not shorted.
                    What DC voltage do you get right at the two legs of the start up cap?
                    • Ralph Green
                      • Feb 2013
                      • 66
                      There is 321V DC.
                        That's the main filter cap - the start up cap is much smaller and near the control IC.
                        • Ralph Green
                          • Feb 2013
                          • 66
                          Near SG6841DZ?
                            Probably -- assuming that is the controller IC.
                            • Ralph Green
                              • Feb 2013
                              • 66
                              There was 10uF/50V replaced with now one but still no luck.
                                We need to see the pictures of the board so there will be no confusion like where that start up cap is.
                                • nogger
                                  • Aug 2010
                                  • 190
                                  Did you check the diodes etc i mentioned in my previous post ? cap polarity & checked for solder shorts on the secondary tracks ?
                                  • Ralph Green
                                    • Feb 2013
                                    • 66
                                    Yes, all checked. Diodes, caps and solder as well.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      was all 15 capacitors replaced there is a full repair kit on ebay although cpc etc will be cheaper imo
                                      • Ralph Green
                                        • Feb 2013
                                        • 66
                                        Yes, all replaced but not by me.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • shovenose
                                          Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                                          by shovenose
                                          Got this one for free because, well, it no worky.
                                          A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                                          Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                                          08-11-2021, 01:26 PM
