Sony XBR-75X800G - Android start up only and dark blue screen
    replied
    As to post #72, I have never seen this person post anything first...that was the correct solution.
    replied
    Also I will say that I have never seen or even read about a sony screen being bad with these symptoms you are having and that covers the last 11 years I've been here and plenty more.
    replied
    So do DIAH'S screen test, that will tell the tale. I don't assume anything, I will say that imo sonys have MUCH less screen issues than most other brands.
    replied
    Well as usual, someone is just running off at the mouth, I wonder who Diah is the one who said to test screen in post #14, this wannabe P is just echoing that FACT. Even if you can't fix it, you have a mainboard that has been passed by a professional tech. If you can not fix the tv you can sell the mainboard, doubt very much that Nicks fee will be anywhere near that so you did not hurt yourself and you don't have to wonder about the mainboard any more. This is obvious but evidently SOMEONE, p, doesn't understand it, people don't work for free, if there's any pro techs out there that want to spend an hour testing my boards for free, by ALL means let me know.
  • Davi.p
    replied
    was there the need of this Nick? i told you first that screen was the clued no.1.. i wonder if he worked for free or what..
  • NolesFan
    replied
    Well I heard from Nicks today and they said that the MB was in perfect working order. They felt that with the MB functional and from what I told them was going on, they thought it was either the LED strips ( which is definitely is not because I can see them light up or the panel itself has failed. I did write back and ask if in any way it could be the Tcon but I havent heard back yet. It would really suck that the panel fails and there is no fix..
  • NolesFan
    replied
    Davi, Im not changing boards, Im having the current one repaired ( if they find anything wrong ).
    bohaboha here are the photos you asked for.
    replied
    UH, not everyone is a tv tech or wants to be so if someone wants to change out boards it's their prerogative. Ever stop to think that TIME is also money??? Anyone with reasonable intelligence realizes that time is even more valuable than money as it can not be replaced.
  • Davi.p
    replied
    Changing boards randomly is never the right way..
  • bohaboha
    replied
    Yes it is absolutely the right way but just for curiosity can we se some pictures of your tv and all the boars thanks in advance for some feedback after Nick
    replied
    I believe Nick gives a warranty also.
  • NolesFan
    replied
    Ya, I tossed around different ideas, buy a used MB and try it, if it doesn't work, buy Tcon and try, but ultimately it was the fact that Nicks guys told me that they ( if they find issue ) they repair the issue and also other known to go bad parts. Seems more logical that route than to buy a used one, and if it does work, get a little time from it before it goes bad because of age.
    I really do wish I understood more of what you guys spoke, but even if it came down to the EMMC being bad, I have no way of fixing that component. When I do have the end result. I will be back to post to give clarity on the issue.
    replied
    Well at least Nick can verify the mainboard one way or another, this tv is direct lit so it might be worth the time and expense. If it were edge lit I would surely not bother with it.
  • NolesFan
    replied
    Originally posted by bohaboha
    Hi all. How did this repair go, have you solved the problem? Tell us if it's so. it's strange that no one asked for pictures of this TV
    Hey bohaboha, TV is as my last post. I don't know enough of these abbreviated terms on what to test or even when they use the full name of part, I don't know what that is on the TV. I've reached out to Nicks TV repair ( the one who has the YouTube channel ) and when I explained the issue and copy and pasted much of what was discussed here, they were perplexed at the issue. Most of what I read, here and other sites, many people seem to think it's the MB so I think I am just going to send it in to Nick for repair. If they find nothing wrong with it, I'll try the Tcon and then after that if it's still not working, I'll throw away the TV.
    Unless you have some thoughts?
  • bohaboha
    replied
    Hi all. How did this repair go, have you solved the problem? Tell us if it's so .it's strange that no one asked for pictures of this TV
  • NolesFan
    replied
    Davi.p Ok your way ( remove lvds cable from MB, jumper a 12v from PSB to tcon fuse, turn on and see full screen colours for the time to eliminate doubts.. ) The tv came on dark blue screen.
    The other way that it was not responsive was Diah's was in post #14, when plugged in, I could do anything and no self test as you say.
  • Davi.p
    replied
    OMG....tv must not turn on normally, main board is detached and isolated, cannot load any software, only tcon circuitry must run, must cycle full screen colours.. is a self test built in the tcon.. tcon is likely be ok, panel maybe is ok, but panel circuitry can be shot, since no load is.present on the.main board cable, maybe 12v rises a bit more and shorted component goes full short, two ways now, check panel strip boards for bad caps, or put a resistive load on the 12v to lower.it and retest screen..
    sorry, third way, an.ATX power.supply can provide around 10,5v when using only the 12v output, can.use.it to power tcon, for the backlight you use the normal PS board with jumpers
  • NolesFan
    replied
    Again today
    connected Pin 5 STBY_3.3V to PIN 9 Power_ON & pin 7 BL_ON & pin 26 T-CON_ON. At the connection of all 4 wires, had a reading of 3.57
    connected 12V from the pin 25 T-CON VCC and put it on the F fuse on the T-con, had a read of 12.51 at the fuse.
    Plugged TV into wall, I got one click.
    After that, the remote or joystick was unresponsive, TV would not turn on
  • NolesFan
    replied
    Originally posted by Davi.p
    how can you jump a single pin to others inserting jumper wires? You need a side without pins and twist copper together.. check the pin outs for correct tensions..
    Jumped from PIN27 TCON_VCC12v to Fuse on TCON. Plugged in, turned on, TV went thru its loading as far as back lighting, but the screen stayed dark blue. Android start up sound played. I verified I was getting the 12v to the fuse and yes I was get 12.+ volts
  • Davi.p
    replied
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • jean luc ferre
    acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
    by jean luc ferre
    on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
    i tried the hard reset, cmos reset, changing the ram without results.
    in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
    The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
    but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
    11-22-2025, 03:54 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • ulthi
    Samsung QE50Q60TAU - Flashes black/blue screen
    by ulthi
    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
    I have tried different resets and have also replaced the main board - but nothin has changed.
    Any suggestions?
    https://youtu.be/acYQ-ImmhWA
    10-14-2025, 01:48 PM
