Sony XBR-75X800G - Android start up only and dark blue screen
    replied
    Do you really want to give up? ALL is not tried yet, now listen up, DO or at least try to do the update/re-pair, no joy then DO these tcon tests, a video is worth a million words. This is one of those youtubers that knows what hes doing, just follow his lead, lets see what we get. once again this is tv repair not brain surgery, these tests are really not that hard, specially with a good how to video right there: https://www.youtube.com/watch?v=P5uD1tzMdUs
  • NolesFan
    replied
    Ok thanks for trying and appreciate the patience. If you have doubt with the standalone test, which Im guessing that means you think either A its the panel or B my skills at the test, then theres no point in going further and Ill scrap it.
  • Diah
    replied
    Originally posted by NolesFan
    Secret to removing them? I took out the screws for the stands and I removed the 3 screws that were holding it down, but there is no play in the plate.
    lol... common.... sorry man. i have doubt right now with yours standalone test and this small things... please seek help from around before you cause unforgivable damage to the set
  • NolesFan
    replied
    Originally posted by Diah
    yes under the metal plate there are the panel buffer boards
  • Diah
    replied
    Diah, you are referring to that panel in the first photo and not to the gold ribbons in the second, correct?
  • NolesFan
    replied
  • Diah
    replied
    turn on tv with signal mean fed the tv with cable or areal or hdmi signal
  • Diah
    replied
    So I removed the speaker and there is nothing behind it. Its just 2 wires coming off it.
    What is the panel buffer boards?
    Im sorry, Im getting lost at what yu want me to do
    under the speaker you will have plate on each side you need to remove them then you will have access to the panel buffer boards which the 2 ribbon cable from T-con connected to them... take look at the middle you will find U ribbon cable connect 2 pieces together on each side
  • NolesFan
    replied
    replied
    "If the set doesn't auto turn on, then press the power button. In rare cases, the board does not require to be paired. If the set turns on and shows picture, you are done, no need to pair the mainboard!"
    Im assuming since I plugged in the MB and it went thru the process and allowed me to perform a factory reset it, it has paired?
    I would run Nicks update/re-pair, its different than a reset, plus its probably the latest firmware for it.
  • NolesFan
    replied
    remove the speaker and let see the panel buffer boards.. on each side you have at the middle U ribbon... try disconnect one a time and turn on the TV with signal to wake up the Soc GPU
    Ill try this now, but what is meant by " turn on the TV with signal " ? Do you just mean to power up tv?
  • NolesFan
    replied
    replied
    Several times and did not perform anything
  • NolesFan
    replied
    Theres a silly little button on remote that you probably already tried, the PIC OFF button.
    replied
    just called Nicks, they said the USB was for pairing the MB back to this TV, so they sent me instructions on how to do and will perform that now.
    yes original remote
    replied
    Firmware update directions there, looks like Nicks already put it on the usb so you can go straight to update procedure: https://www.sony.com/electronics/sup...tware/00262031
  • Diah
    replied
    replied
    Oh and Nicks did send me a USB drive bac with my MB but no information with it. When I plugged into my computers and I checked the file name it was " upgrade_loader.pkg " I dont have a program on my computer to open it, but figure its something for the TV. I was going to call them today and ask about it. Bad thing is though, if its some kind of firmware updater or something, without being able to see anything on screen, I wont be able to do anything with it.
    I believe thats the firmware update.
  • NolesFan
    replied
    yes original remote
    replied
    Well the screen shows me nothing ( meaning cant see any message appear ) but I did hold down the remote power, tv shut off and rebooted, LED lights cycled, but no display.
    Tried the unplug and hold manual button down for 30 seconds and plugged back in, and LED lights cycled but no display.
    Tried a hard reset with the power and down buttons held, green lights faded in and out on little light below the TV, then let go, little light went to white, LED lights cycled, but no display.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • ulthi
    Samsung QE50Q60TAU - Flashes black/blue screen
    by ulthi
    My tv is not able to turn on. I flashes between black and vague blue screen (see video)
    I have tried different resets and have also replaced the main board - but nothin has changed.
    Any suggestions?
    https://youtu.be/acYQ-ImmhWA
    10-14-2025, 01:48 PM
  • Adam Russ
    Black screen on Sony 65x90ch (65x900h from Costco)
    by Adam Russ
    Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
    09-15-2024, 05:46 PM
