Samsung TV won't turn on ... keeps cycling the power relay on & off
  • Journey11
    • Jul 2024
    • 8
    Hi All,
    First time posting here ... my name is Kevin but my friends call me Journey.
    I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
    After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
    It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again.
    Also no standby light. I saw a couple you tube vids with same issue and they just replaced MB and problem solved ... mine apparantley different story.
    I called the shop who sold the board to me to get a history of this MB ... whether used or new and I think he said they got new from Samsung.
    Anyway, he told me that no standby light is the issue and said the power for that comes from the power supply board which it does not.
    That power button and LED plug into the MB. I rechecked the PS board for correct voltages and it looks good so I can't see where the problem might be.
    Any ideas would be helpful ... thanks in advance
    Journey
    PS if any pics are requested I will accomodate.
  • ResetReality
    • Jul 2024
    • 3
    • Malaysia
    Disconnect the screen connector lvds cable....does it stay on?
    • Journey11
      • Jul 2024
      • 8
      I'll give that a try ... thanks.
      • Journey11
        • Jul 2024
        • 8
        Hello Reset,
        Well I tried your suggestion and something happened. First tried both ribbons discoed and lo & behold it stayed on. So then tried connecting just one ribbon and it stayed on. Both connected back to cycling on/off again.
        Then tried one again but the other side this time and it stayed on again. So the three times it stayed on there was only back lights on and checked the standby LED on the front and it didn't seem to be doing anything.
        Included are some pics of the rig. Click image for larger version
ID:	3302583 Click image for larger version
ID:	3302584 Click image for larger version
        So at 1st I thought the first disconned ribbon was a bad side of either the screen or the pcb that attaches to the screen and the ribbon. But that didn't hold up as the side I thought might be bad/toast was then connected and the other side not it stayed on. SO it's only when both ribbons are connected that it cycles again.
        • lotas
          • Jan 2016
          • 4805
          • Russia
          You first need to install the jumper, and then experiment with lvds tapes.
          • Journey11
            • Jul 2024
            • 8
            What's the jumper for or do and what am I looking to see or find ?
            • lotas
              • Jan 2016
              • 4805
              • Russia
              The jumper creates feedback between the motherboard and the panel, when any lvds cable is disconnected, the connection between them is lost and the motherboard blocks the supply voltage for the panel at the t-con. When you install the jumper, you deceive the motherboard (as if the panel is connected) and now you can disconnect one cable at a time. check which half creates the defect.
              • Journey11
                • Jul 2024
                • 8
                Great Thanks ... but if you didn't notice in the pix ... this unit doesn't have a separate T-Con, just the long strips that run along the bottom of the screen.
                I'll let ya know what I find.
                • lotas
                  • Jan 2016
                  • 4805
                  • Russia
                  I am aware that modern Samsung models have t-con built into the motherboard.
                  • Journey11
                    • Jul 2024
                    • 8
                    Hi I'm Back,
                    Well did the jumper trick and got one side of TV to display (Right side) When left side connected I get darkish screen backlit but no image. I'm guessing the screen is shot ?
                    Remember no separateT-Con. Or is there a component that can be isolated on the long pcb strip along the bottom of the screen the attaches to the screen ?
                    Click image for larger version  Name:	20240706_173317(0).jpg Views:	0 Size:	4.94 MB ID:	3304050 Click image for larger version
                    • Journey11
                      • Jul 2024
                      • 8
                      Hi Reset,
                      One thing the original owner said ... the TV was barely a year old. I can't imagine the screen died after only a year ?
                        • 12307
                        • U.S.
                        Can you post some good clear pics of "long pcb strip along the bottom of the screen" maybe someone can help from there.
                        • EazyBone
                          • Jun 2023
                          • 1361
                          • United states
                          Edit oops
                          • usbdevice
                            Acer X223HQ (Version Bbd) on/off-power-cycling
                            by usbdevice
                            Hi all
                            There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                            https://www.badcaps.net/forum/showthread.php?t=50657
                            https://www.badcaps.net/forum/showthread.php?t=40512
                            The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                            It's my dad's old monitor. He...
                            08-05-2022, 02:21 AM
                          • valvashon
                            Samsung UN55FH6030: random power cycling
                            by valvashon
                            Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                            About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                            Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                            10-20-2023, 09:59 AM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • high-tech
                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                            by high-tech
                            Hello everybody, I could use some help on this one... It's got me guessing...
                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                            9. ground (PWM2) 10. 0.9 volts cycling...
                            09-15-2020, 03:39 PM
