Hello i am looking for firmware i have a 50 inch tv stuck in bootloop Vestel 17mb185 VES500QNDH . I have tried with another 17mb18180e same thing maybe both are bad . Thanks
Tags: None
Hello there. Help with VESTEL tv Daewoo d55dm54uans main 17mb185 The client complained that there was no HDMI video from Tricolor and sonyPS 5 consoles. I was in the service after the update, apparently all the keys were flashed. I looked at the information on the Internet and with the help of a flash drive I was able to get the sony PS 5 to work, I ordered HDCP from the flash drive. And CI+ does not understand where to get the Credentials.bin file And how to sign it correctly? and without it, the tricolor is just a black screen...Comment
by massimomaxChiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
by anluHello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model... -
by piernovHi,
Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
I suspect corrupt firmware but I haven't been able to find anything for this TV.
TV model: Finlux 65-FUC-8060
Mainboard: Vestel 17MB130S 23473048
Panel: VES650QNTS-2D-U11
At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel. -
by FalukyAfter an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
Best regards.
Anyone got their hands on firmware for Marantz SR5008 stuck in update loop-
by FlashFireSixI took an ebay gamble on an LG xboom pn5 speaker which was listed as having battery issues (turning on then off).
I got it earlier today and concluded it's in a demo mode because of the following:- When it's plugged in, it'll turn on and the power button will not turn it off
- Battery is healthy, reading 4.2v and not swollen, charges according to the xboom app
- the play/pause and volume buttons don't work
- You can pair to it and play music fine, as long as it's connected to power
- The bluetooth connection is disconnected after 5 seconds of audio pausing
- The DTS setting is defaulted
- Loading...
