Vestel 17mb185 VES500QNDH
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    Hello i am looking for firmware i have a 50 inch tv stuck in bootloop Vestel 17mb185 VES500QNDH . I have tried with another 17mb18180e same thing maybe both are bad . Thanks
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    • Diah
      • Feb 2013
      • 6440
      test LED BL
      • porfyriadhs
        • Oct 2023
        • 80
        • Greece
        The problem withthe tv is mainboard leds are ok need to reset firmware
        • porfyriadhs
          • Oct 2023
          • 80
          • Greece
          OK fixed the mainboard but the colours are weird . any help ?
          • yokoono
            • Apr 2010
            • 505
            Type menu 4725 and put the picture here.​
            • garsiasergei
              • Feb 2022
              • Россия
              Hello there. Help with VESTEL tv Daewoo d55dm54uans main 17mb185 The client complained that there was no HDMI video from Tricolor and sonyPS 5 consoles. I was in the service after the update, apparently all the keys were flashed. I looked at the information on the Internet and with the help of a flash drive I was able to get the sony PS 5 to work, I ordered HDCP from the flash drive. And CI+ does not understand where to get the Credentials.bin file And how to sign it correctly? and without it, the tricolor is just a black screen...
              • sordids999
                • May 2013
                • 2161
                • uk
                Hi does anyone have the firmware for a Panasonic 50lx650 main board 17mb185
                Screen ves500qnzh-n2-z01
                23798312
                • Bazilwrc164
                  Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                  by Bazilwrc164
                  I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                  The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                  I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                  If anyone can provide:
                  • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                  • Or a compatible EEPROM dump
                  07-23-2025, 12:15 PM
                • Daniel Larsson
                  Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                  by Daniel Larsson
                  My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                  I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                  During these seconds the function button is not working...
                  08-13-2025, 10:29 AM
                • massimomax
                  Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                  by massimomax
                  Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                  spero che qualcuno può averlo per riprogrammare eprom. grazie
                  Post in English !!!
                  I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                  02-28-2025, 07:27 AM
                • anlu
                  Vestel Firmware - Toshiba 32W133DN
                  by anlu
                  Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                  Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                  02-04-2023, 12:59 AM
                • piernov
                  Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                  by piernov
                  Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                  I suspect corrupt firmware but I haven't been able to find anything for this TV.
                  TV model: Finlux 65-FUC-8060
                  Mainboard: Vestel 17MB130S 23473048
                  Panel: VES650QNTS-2D-U11
                  At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                  06-01-2024, 12:57 PM
