Z-sustain: From a bad board, to a sparking power supply board, back to good!! VIDEO
  • sugar_ray
    • Dec 2012
    • 121
    Howdy all!! hard to believe its been over a year ago now since I dipped into the "repair flat screens as a hobby" game. it all started for me on these forums. I have salvaged several flat screens since my first repair. very rewarding game to be playing.
    Anyways.......the first flat screen i ever repaired was mine. A BenQ46W1, Only BenQ in name as they NEVER designed their own panels. its nothing more then a Gateway P46M103 re branded with the BenQ name. Tatung made the panels. Even though the panel was designed in 2004, there seems to be an endless supply of parts available online (lucky for me) and most of all, very in-expensive.
    Over a year ago my Q-display croaked, I began reading and asking questions. End result was a bad Y-sust. board. replaced it and the panel was trouble free for over a year. Couple weeks ago, it started acting up. WHITE PIXEL flashes when i powered on or off. distorted color (tough to see in the video) but above all, you could hear it sparking inside when powered on or off. it had the classic symptoms of a bad Z-sust. board. But......the sparking had me curious and I was eager to investigate!! perhaps cause this set was my first repair I have an emotional attachment to it?? who knows?? I realize its not worth anything, but for $36 total in parts It was fun to repair it AGAIN
    Short Video Journal of the repair:
    http://www.youtube.com/watch?v=29Iqv...ature=youtu.be
  • sugar_ray
    • Dec 2012
    • 121
    Re: Z-sustain: From a bad board, to a sparking power supply board, back to good!! VID
    Ok
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Good job!
      Man, that was a bad bad solder joint. Those are the ones that start fires! Look at how the solder was pitted from the sparking!
      Muh-soggy-knee
      • sugar_ray
        • Dec 2012
        • 121
        No doubt bro!! Not sure how those develop?? Weak off the production line only to fail over time??!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          After all of...
          07-13-2024, 08:14 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Nicktronic
          Samsung Power Supply Board BN44-00874F
          by Nicktronic
          Hey everyone,
          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
          Anybody...
          03-17-2025, 06:20 AM
        • ohren
          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
          by ohren
          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
          The models launched in 2018 and 2019 respectively....
          09-08-2023, 05:24 PM
