I think I just lost a laptop and a TV to a bad HDMI cable.
  • mattpd
    • Oct 2012
    • 302
    So, earlier today I had a perfectly running laptop and 55" Hitachi TV. I decided to hook up a 4x1 HDMI switch because my TV only had 1 HDMI input. I hooked it up with known working HDMI cables, but I didn't get any signal. I sat down to do some research and a few minutes later I heard a POP and HISS from the 4x1 switch. I quickly unplugged it, and realized I had put a 12v power supply on the switch when it only required 5v .
    I then plugged my TV back into the cable box like it was originally hooked up, through the HDMI cable that once worked. NO SIGNAL. Thinking it could be the cable box that was not working, I then hooked the HDMI cable into my laptop. The instant the cable went in the HDMI port, the laptop shut off and now it won't come back on. The TV does power on, and gives an on screen display, but will not receive a HDMI signal. It also will not tune into antenna channels either, I just get a black screen.
    I assume it's a mainboard problem with the TV, right? Have anyone ever experienced something like this before?
    TL;DR: I overvolted an HDMI switch on accident, and it fried my HDMI cable/the TV's main board. Not knowing this, I plugged the HDMI cord into a laptop, and it killed that too. Crappy day it's been
    Re: I think I just lost a laptop and a TV to a bad HDMI cable.
    typically, the HDMI switch will suck power from the source, which should feed 5V at up to 50mA through a diode. It's possible that the switch just connects this to 12V, so you could have caused the 5V supply in the TV to fail and shoot up to a higher voltage.
    • mattpd
      • Oct 2012
      • 302
      After possibly destroying the mainboard with the faulty switch, is it possible said mainboard would then cause a laptop to fail catastrophically when connected to the TV via HDMI (switch is out of the picture at this point)?
        That's possible but I think it is reasonably unlikely, I would check other things on the laptop, remove battery and unplug AC, then try again.
        • mattpd
          • Oct 2012
          • 302
          I wish it was that easy. I took the battery out over night, and the CMOS too. No results. Time for a new mainboard and motherboard I guess.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Well I am spreading a rumour that hdmi is not plug and play and all machines should be switched off /unplugged connected then switched on again.
            Having seen many cases of hdmi killing boards I have told my family and friends
            not to do it.
            Too late for you, sorry, but others might read this and save their sets.
            Maybe you can start a thread for laptop on laptop forum post good clear pictures of the board make model number and NAME of board. Close up of hdmi area.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              got to say a freind also had this problem the other night whilst connecting his laptop to a tv with hdmi whilst both units switched on now the laptop just turned of now wont start up at all just a quick flash from a led i think.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                I dont like HDMI for this very reason. Not had any issues Personally, but seen the results and heard the sad tales of problems--Often kids and Playstations/X-Boxes come to mind....
                (Never owned either--and dont ever plan to!)
                At least with SCART (Peritel) the reported incidents of problems were much less--even though the resolution/quality isnt quite the same!
                TELEFIX
                • mattpd
                  • Oct 2012
                  • 302
                  Yup, all I get is a flash from the power LED every once in a while.
                  not to do it.
                  Will do as soon as I get the laptop broken down. I will also post a pic of the mainboard in this thread as soon as I get this insanely heavy TV off the wall.
                  Although I don't plan on doing it again, I have been haphazardly plugging/unplugging HDMI ever since my first HDTV with no problems. I think it was carelessness with the 4x1 switch that caused this whole problem.
                  • ivtec
                    • Dec 2008
                    • 1967
                    Hi guys,i also got a cheap switch i had no ussues i did not use the 5 volt power though, i did switch manually when i need to switch between ps3 and a sat receiver.But as someone suggeted always turn off sources when connecting switch with the power supply connected.
                    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                    • mattpd
                      • Oct 2012
                      • 302
                      I just ran into a small problem... I was about to buy a replacement Sub Digital PWB, part numberJP50322 (which I have been calling the mainboard in this thread) but noticed it does not contain the HDMI ports. The HDMI ports are actually on the C Main Digital board, part number JP50763.
                      Do you think I need both boards? The TV is a Hitachi 55HDT79
                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-06-2024, 05:30 AM
                      • Ungenau
                        Search lost component. Nintendo Switch MAX77620A
                        by Ungenau
                        Hallo.
                        Search lost component from Switch PCB by MAX77620A
                        Thank for Help....
                        01-19-2025, 02:40 AM
                      • Natob82
                        Micro Momentary Push Switch?
                        by Natob82
                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                        12-21-2022, 05:22 AM
                      • grimacelord
                        NEC TurboExpress On/Off Power Switch Replacement Help
                        by grimacelord
                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                        11-09-2023, 09:49 AM
                      • SluggerB
                        Help making a switch work the opposite way with a relay
                        by SluggerB
                        I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                        I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                        It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                        02-07-2025, 07:57 PM
