Samsung LE37A456C2D - image retention issue
+ More Options
Posts
    Re: Samsung LE37A456C2D - image retention issue
    Panel or t-con, main would not cause this, panel more likely.
    • noledud
      • Dec 2013
      • 413
      • united kingdom
      ok thanks tom - i will try a tcon as i cant try a panel lol
      • wreksta
        • Aug 2013
        • 508
        • england
        a lil bit info from expeirence could be the side ribbons if it has them down the left and right of the panel they are little one inch ribbon tabs with little component on
        you will have to remove the panel from the tv then the metal frame supports from the front of the panel
        i find if i only remove the top and the sides screws the frame will tilt toward you enough to gain access this way also secures the lcd in the frame
        drastic you may say but if it has them try pressuring it or slowly peel from panel watch picture if it improves remove whole tab
        this has worked for me with a few samsung A models
          What??? Do NOT pull the tabs off!!! This kills the panel.
          • wreksta
            • Aug 2013
            • 508
            • england
            tom i did say was drastic but i have had sucess in past by removing the very top far right tab and tv still lives and beautifull picture mate
              Well, I would be extremely surprised if that didn't leave you with a dead panel. I suspect as this is a 720p AUO panel it uses only left or only right hand gate drivers anyway.
              • noledud
                • Dec 2013
                • 413
                • united kingdom
                #27
                ok got the new tcon - bought as "tested"
                so i have good news and bad news
                good is the image retention does not happen anymore
                now the problem is colour washed out like an xray sort of thing
                iv read this is the gamma chip is that correct also how difficult is it to replace?
                  Can you see any points marked VGAMA1 thru VGAMA22 or so? Test the voltage on each.
                  • noledud
                    • Dec 2013
                    • 413
                    • united kingdom
                    #29
                    this is bad IR tcon so i take it that refers to the IC in the top left of the pic ?
                      The group of test points marked VGAMA1, etc. You will have to find some of the missing ones (need to get all from VGAMA1 thru VGAMA22 or whatever it goes up to.)
                      • noledud
                        • Dec 2013
                        • 413
                        • united kingdom
                        #31
                        there are 16 points there and only 14 on the lable
                          There's a box around the gamma points. The other two are independent points for other signals.
                          You also need to find VGAMA3,4,5,9,18,19,20 which are going to be scattered elsewhere around the board.
                          • noledud
                            • Dec 2013
                            • 413
                            • united kingdom
                            #33
                            update on this - gamma tested bad - got a new chip installed and tv works fine now
                            • comptek
                              • Aug 2013
                              • 606
                              #34
                              Hi All i have the same issue on the same tv
                              but the picture makes everyone look like Dale Winton or Des O'connor
                              Dark picture all over and has image retention swapped t-con and still the same
                              any ideas please
                              Regards
                              Gary
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                #35
                                any ideas please
                                Regards
                                Gary
                                Check Gamma Voltages as described above. Chances are you bought a duff T-Con.
                                TELEFIX
                                • comptek
                                  • Aug 2013
                                  • 606
                                  #36
                                  will try thank you Alastair
                                    09-07-2024, 05:50 AM
                                  • shlomim412
                                    samsung ua55es6800 - no image
                                    by shlomim412
                                    hi
                                    having problem with samsung ua55es6800
                                    tv had backlight on, sound working - responds to the remote control but no image.
                                    check tcon board - had 12v in but no other voltages present.
                                    when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                    when leaving only left side connected - again no voltages and no image.
                                    put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                    kept trying to block less pins on the left ribbon cable...
                                    05-15-2024, 05:00 AM
                                  • vincentedel
                                    Samsung SyncMaster 740n Phase Control Issue
                                    by vincentedel
                                    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some timeβ€”like after playing a gameβ€”the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                    04-22-2025, 12:33 AM
                                  • Manucsl
                                    QE65Q800TATXXC Samsung TV Issue
                                    by Manucsl
                                    Hello.
                                    My TV is a QE65Q800TATXXC Samsung TV.
                                    Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                    Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                    Any ideas to check would be very appreciated 😊
                                    After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                    02-19-2025, 07:47 AM
                                  • FourRunner
                                    Display issue Samsung TV UA65JS9000W
                                    by FourRunner
                                    I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                    10-03-2024, 07:05 PM
