Pioneer PN50951-22U Backlight On, No Image
  • x_orange90_x
    • May 2015
    • 710
    I get backlights that stay on not there is no image. The tv does not automatically power on when plugged in either which I generally see happen when there is a fault. It responds as it should to the power button.
    I checked the test points on the TCON and I have proper voltages except for at 1P15V. I don't know if that is supposed to be 15V or 5V, but either way I only get 1.134V on that point. I have 12V, 8V, VCC, and a small amount on the CKV point.
    I tried heating up the SoC on the main board but that made no difference. Disconnecting either ribbon from the TCON also makes no difference.
  • EazyBone
    • Jun 2023
    • 1321
    • United states
    Disconnect one ribbon from tcon to panel at a time and see if you get half image
    • x_orange90_x
      • May 2015
      • 710
      That was the last thing I said in my post. No difference. I reseated the lvds ribbon too.
      • lotas
        • Jan 2016
        • 4589
        • Russia
        I wonder where the supply voltages VGH, VGL, VCOM, AVDD are...
        • lotas
          • Jan 2016
          • 4589
          • Russia
          At this test point there is 1.8v?
          1P15V - 1.15V
          • x_orange90_x
            • May 2015
            • 710
            1P15V - 1.15V
            1P15V - 1.123v
            ​​​12V - 12v
            VCC - 10.32v
            SCL -3.28v
            SDA - 3.27v
            CK2-TCON - 1.356v
            Those are the only labeled points I see besides TEST and that starts out negative mV and slowly rises into the positive mV.
            • lotas
              • Jan 2016
              • 4589
              • Russia
              1P8V -- 1.8V ?
              • x_orange90_x
                • May 2015
                • 710
                1P8V -- 1.8V ?
                Oh sorry. In my first post when I said 8v was 8v that was the point I meant. So 1P8V - 8v
                • lotas
                  • Jan 2016
                  • 4589
                  • Russia
                  Why 8v and not 1.8v.
                  3P3V - 3.3V
                  1P8V - 1.8V
                  1P15V - 1.15V​
                  • x_orange90_x
                    • May 2015
                    • 710
                    3P3V - 3.3V
                    1P8V - 1.8V
                    1P15V - 1.15V​
                    I will recheck it.
                    • EazyBone
                      • Jun 2023
                      • 1321
                      • United states
                      I see that now whoops, read differently.
                      • x_orange90_x
                        • May 2015
                        • 710
                        3P3V - 3.3V
                        1P8V - 1.8V
                        1P15V - 1.15V​
                        3P3V - 3.25v
                        1P8V - 1.78v
                        1P15V - 1.14v
                        • lotas
                          • Jan 2016
                          • 4589
                          • Russia
                          3P3V - 3.25v
                          1P8V - 1.78v
                          1P15V - 1.14v
                          Well, everything matches, now we need to get to the buffer strips and see what is soldered on them...
                          • x_orange90_x
                            • May 2015
                            • 710
                            I noticed there's a buzzing that comes from the main board when the power is off but plugged in, and it turns into a lower hum when power is on. It comes from the lower part of the main.
                            • x_orange90_x
                              • May 2015
                              • 710
                              What would the chances be that something is wrong on ONE of them that causes both sides not to work, or something being wrong on BOTH sides? I get zero image on either side with TCON ribbons removed, alternately.
                              • lotas
                                • Jan 2016
                                • 4589
                                • Russia
                                Your second part of the t-con is soldered to the strip, where all the main voltages for powering the panel are formed.
                                • Diah
                                  • Feb 2013
                                  • 6363
                                  its is MB issue.. check after the soc low voltage id there TESTED OK--- WE HAVE IN THIS FORUM SAME ISSUE:: ::
                                  • lotas
                                    • Jan 2016
                                    • 4589
                                    • Russia
                                    https://www.badcaps.net/forum/troubl...50951-22u-dead
                                    • x_orange90_x
                                      • May 2015
                                      • 710
                                      I reviewed that thread before making my own post. I have backlights though so my issue is somewhat different I think. Nonetheless I'm still suspecting the main board. Is there anything I can/should check on the main?
                                      • x_orange90_x
                                        • May 2015
                                        • 710
                                        I looked at the strips and see several more test points, but didn't see VGH, VGL, etc. I did see VCC however. I will recheck later today when I am home.
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • MDY94
                                          Hitachi 50HK6100U display issue
                                          by MDY94
                                          I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                                          12-18-2024, 12:31 PM
