Tv Philips 55PUS6031 no image, backlight ok
  • Raulnn
    • Nov 2022
    • 103
    • España
    good night! I have this TV, with quite poor build quality. It has a tcon integrated into the panel, a single flex from the tcon to the panel, and the 2 panel controller boards joined by glued flexes. There is no way to separate them.
    The symptom is that the image is not visible, but the backlight works. How to know if the problem is in the main or in the tcon-panel? I can't override zones.
  • lotas
    • Jan 2016
    • 4578
    • Russia
    Philips 55PUS6031 t-con is not built into the motherboard, it comes separately...
    • Raulnn
      • Nov 2022
      • 103
      • España
      55pus6031S
      • lotas
        • Jan 2016
        • 4578
        • Russia
        Well, if with the letter “S”, then this is a completely different chassis (Vestel).
        • yokoono
          • Apr 2010
          • 481
          In the marked place there should be a fusible​. Check if it is good and if they are 12V. Have you rewritten other software?
          • Raulnn
            • Nov 2022
            • 103
            • España
            fuse ok. It's the first thing I did. I haven't rewritten my software because I don't know how to get it. I understand that you mean doing it via USB format. thank you
            • Raulnn
              • Nov 2022
              • 103
              • España
              someone?
              • yokoono
                • Apr 2010
                • 481
                Main is 17MB120. Cod panel (VES550xxx-xx-xx) ??. Passed on the white label left/top.​
                • Raulnn
                  • Nov 2022
                  • 103
                  • España
                  Yes. 17MB120 VES550QNDS-2D-U12
                  • yokoono
                    • Apr 2010
                    • 481
                    If you rewrote the wrong software and it was for another panel, it is possible that the TV will no longer have an image. Below is a software for what you have on TV. If the problem is hardware, this software will not solve the problem. The software is for the stick. The installation procedure is mentioned on the site many times. If, after rewriting, the remote control no longer works, you can use a programmable one. Try at your own risk.
                    https://files.fm/u/5rc3aa2k34
                    • Raulnn
                      • Nov 2022
                      • 103
                      • España
                      I haven't done any tests yet. The TV has not been tampered with. The TV is intact, but it gave that error. Thks
                      • malekservis
                        Philips 58PUS8536/12 Backlight ok, no image
                        by malekservis
                        the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                        Any information would be appreciated....
                        08-07-2024, 07:48 AM
                      • Salem Aboshala
                        820-00138-A got image but no backlight
                        by Salem Aboshala
                        Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                        I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                        History: my laptop backlight stopped working without any reason.
                        Symptoms:
                        I have image on screen using my flashlight.
                        I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                        Keyboard backlight still working and can be adjusted normally.
                        Since two days I tried to follow all similar...
                        06-11-2024, 03:02 PM
                      • chestercc
                        Philips TV Backlight Repair
                        by chestercc
                        So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                        My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                        The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                        11-18-2022, 01:15 PM
                      • zaurus81
                        Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                        by zaurus81
                        This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                        The board is equipped...
                        01-16-2025, 03:54 AM
                      • ohren
                        Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                        by ohren
                        I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                        The setup is basically:
                        Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                        Transistor is switching the 3.5 V supply on the power board....
                        12-05-2024, 11:10 AM
