Samsung UN60EH6050F Sound-no picture
    Re: Samsung UN60EH6050F Sound-no picture
    Black probe of the meter on the chassis GND, the Red probe on D1+, D1-, D2+, D2-.
    Your power supply board is not the same as in the Video, you have two sets of LED strings with its own boost converter and its own MOSFET for each string of the LED. The board in the Video has one string of LED.
    So set your meter to higher Voltage scale and take the readings again.
    • eychin
      • Jun 2014
      • 16
      Thank for your help. I apologize for not getting back in a timely fashion. i redid the measurement.
      with the power on and the tab connected, the voltages are:
      1. D1+ 26.0
      2. D1+ 26.0
      3. N.C 0.0
      4. D1- 218
      5. N.C 0.0
      6. D2+ 26.2
      7. N.C 0.0
      8. D2- 219
      9. D2- 219
      with the power on and the tab DISCONNECTED, the voltages are:
      1. D1+ 0.0
      2. D1+ 0.0
      3. N.C 0.0
      4. D1- 300
      5. N.C 0.0
      6. D2+ 0.0
      7. N.C 0.0
      8. D2- 300
      9. D2- 300
      so, is this PSB good?
      Thanks again.
        1. D1+ 26.0
        2. D1+ 26.0
        3. N.C 0.0
        4. D1- 218
        5. N.C 0.0
        6. D2+ 26.2
        7. N.C 0.0
        8. D2- 219
        9. D2- 219
        1. D1+ 0.0
        2. D1+ 0.0
        3. N.C 0.0
        4. D1- 300
        5. N.C 0.0
        6. D2+ 0.0
        7. N.C 0.0
        8. D2- 300
        9. D2- 300
        Thanks again.
        It looks like you have D1+ D1-, D2+, and D2- all backward.
        The D1+ pin is the Voltage feeding pin to the Anode of the D1 LED sting #1 which should be around 224V as printed on the board, D2+ pin is the Voltage feeding pin to the Anode of the D1 LED sting #2 which should also be around 224V.
        D1-, D2- are the Cathode return for the two LED strings.
        You are getting about 300V when no LEDs connected so that is correct.
        So are you sure that you are not getting any backlights at all?
        Pictures provided by shojimmy.
        http://www.shopjimmy.com/catalogsear...?q=BN44-00500A
        • eychin
          • Jun 2014
          • 16
          i'm sorry i wasn't clear. the blacklights are on when the power is on and the tab is connected. the blacklights are not on when the power is on and the tab is disconnected. i see that i could have misinterpreted the orientation of the wires vis a vis the legend. if that is true, based on what you wrote, the voltage readings are correct. if they are correct, then the PSB is fine?
            09-07-2024, 05:50 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Dodgethis
            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
            by Dodgethis
            Hello all,
            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
            09-11-2024, 07:39 AM
