Problem after Replacing Screen on Samsung 32" LCD LE32A455C1D
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi there guys have a Samsung LE32A455C1D given to me by a neighbor because it had a smashed screen, because it was a white TV and looked rather nice (girlfriend wanted to keep it) i decided to see if i could get a LCD screen for it. the picture indicates the label of the original LCD panel, here is the link to the one i purchased : http://www.ebay.co.uk/itm/2812547981...84.m1497.l2649
    after i recieved screen and installed the tv switched on as normal and so did backlight but no picture. could someone shed some light on this or have i purchased wrong screen ?
    Re: Problem after Replacing Screen on Samsung 32" LCD LE32A455C1D
    Did you use old t-con or one with panel?
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      the one that was original with the TV Tom66
        The panels are different revision, which might cause this problem - you would need to make sure you use the right t-con in the right panel.
        It could also be a bad LCD panel. Did seller indicate how panel was tested and verified working?
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          no i will ask him and get back to you, Tom66 do you know what T-Con board would be used and would this work on the original Main/AV board ?
            It would work with original AV board but I wouldn't have a clue what t-con it uses... only the seller would know as I guess from that photo it was supplied minus t-con.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              ok thanks Tom will mail the seller and get a little more info thanks
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                Hi Tom66 i mailed the seller and this was the response "Hi all panels are removed from working tv.100% working part.Original t-con board for this panel is 320AA05C2LV0.0." how will i find out if that T-Con board is compatible with my AV/Main board
                  Check P/N. Who pulls working panel from working TV? Surely TV assembled is worth more. Questionable.
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    yeah i know would think the same thing Tom..
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Here in the States, a working 32" Samsung is worth between $100 to $150. If you get $75 for the panel, $75 for the main, $50 for the PSU, $20 for the T-Con, $10 for the remote, and another $20 for the base, you've done pretty well ($250) with a 32" TV.
                      Though I would still wonder who would pull apart a working TV.
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        i have ordered a T-con board for this display, will wait to see what happens...
                        • Mikeyboy2007
                          • Mar 2013
                          • 745
                          • Scotland
                          ok Tom66 ordered T-con board for that LCD panel and when i put the ribbon in it just get coloured lines running back and forward on the screen, what could be the problem.. i tried putting LVDS cable in other way on main board but just got black screen.
                            Could you show us a video of the fault?
                            • Mikeyboy2007
                              • Mar 2013
                              • 745
                              • Scotland
                              Tom66 http://www.youtube.com/watch?v=JJxjR...ature=youtu.be
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                did you manage to look at that video Tom66 ?
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Do those lines change at all--say with scene/channel change or bringing up the menu etc?
                                  TELEFIX
                                    Good chance you've got a bad panel there. Same model I did in black with similar fault...
                                    https://www.badcaps.net/forum/showthread.php?t=25839
                                    I reckon you've been sold a dud panel mate... This is why I really don't bother with panel replacements as you just don't know if panel is ok
                                    Sorry...
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      Ive Loads of different panels at work--but seldom try changing a broken one anymore either--Just too much hassle, and it usually ends up wasting loads of time and effort!
                                      For the most part--I dont even save them anymore either--Unless I can see it with a picture,--then again the set gets done if its That good, and not scrapped!
                                      TELEFIX
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        no they dont move or change colour etc when i press menu or input / change channel etc
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
                                        • CityZen
                                          Samsung un48ju6700 half screen ghosting problem
                                          by CityZen
                                          This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
                                          I went into...
                                          11-24-2021, 12:03 AM
