Samsung LH82QENELGC/EN Help needed - Static line on screen
  • Kiberge
    Kiberge
    • Apr 2024
    • 10
    • Norway
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when there was a glitch in the main power for half a second. Just a glitch long enough to turn off/on all power in the building. When tv restarted the fault was there. Nothing else electronic as damaged in the building.
    The TV was replaced with a new one, and the old one was free to grab 😊
    I've opened the tv and checked for loose connections and signs of overheated or burned circuits on the circuit boards.
    And I tried to swapping places on the ribbon cables between the t-con and the screen (COF's?) to see if the fault moved on the screen.
    I've also tried to wiggle on the COF and move the ribbon cable between the COF and the LCD screen without anything happening.
    Anyone that would like to set a diagnose? Screen, COF, T-con??
    If the COF or screen are broken, I guess there's nothing to do.
    But could the fault be in the t-con board? Would it be any sense testing another t-con?
    Regards Knut​
  • Kiberge
    Kiberge
    • Apr 2024
    • 10
    • Norway
    • Diah
      • Feb 2013
      • 6367
      for me its not connection issue .. or COF.. its data lost. upload photos please of the main boards t-con and the LVDS, let see its just one or double
      • Kiberge
        Kiberge
        • Apr 2024
        • 10
        • Norway
        Is this what you wanted?
        • Diah
          • Feb 2013
          • 6367
          extract this archive and copy all photo on USB root. and play them on the set., let see how it will act with USB source and flat data
          • Kiberge
            Kiberge
            • Apr 2024
            • 10
            • Norway
            This is how the images looks like
            • Diah
              • Feb 2013
              • 6367
              1- you can play this test again with one ribbon discommoded a time.
              2- could you remove the heat sink from MB and let see clear high resolution photo to know more about the signal... if there another CPU beside the main Soc
              • Kiberge
                Kiberge
                • Apr 2024
                • 10
                • Norway
                If you mean like this, there's no image showing on screen, only backlights.
                • Kiberge
                  Kiberge
                  • Apr 2024
                  • 10
                  • Norway
                  Heat sinks removed from both boards​
                  • Diah
                    • Feb 2013
                    • 6367
                    okay... the best way to narrow the issue.. you need to run the T-CON and panel as stand alone.... it mean
                    1- disconnect the LVDS cable between Mainboards and T-con from T-con side
                    2- disconnect the socket between powerboards and mainboards BL will come on..
                    check the Fuse close to black sockets at t-con if it had 12V with this configuration .. if doesn't have you need to unplug the sockets and fed the fuse with 12V from PSU cold area 12 rail
                    • Kiberge
                      Kiberge
                      • Apr 2024
                      • 10
                      • Norway
                      Removed these two cables and I've got 12v at this fuse.
                      Baclight on, but screen's only black, no image.
                      • Diah
                        • Feb 2013
                        • 6367
                        sorry man.. there are no more test we can do, only i can say for me this issue lost data from this line under the SoC if its BGA or defect Soc channel... only Oscilloscope and data sheet of repair manual belong to this mainboards will help.
                        • Kiberge
                          Kiberge
                          • Apr 2024
                          • 10
                          • Norway
                          So next logical step would be to search for a second hand main board then?
                          • Diah
                            • Feb 2013
                            • 6367
                            No at this moment i wouldn't recommend for replacement, take out the LVDS between MB and t-con and check with high resolution focused photo of the contact pins from both side
                            • Kiberge
                              Kiberge
                              • Apr 2024
                              • 10
                              • Norway
                              All the contact pins looks ok.
                              I also turned the LVDS around 180 degrees. So, I connected the end that was on the MB to the T-con and vice versa.
                              In my thinking, if the fault was in the LVDS or a PIN the fault should have been different, or the line should have moved on the screen because the faulty pin vas moved?
                              • spice_disc
                                Vizio TV M50-C1 reboot cycle and static on screen
                                by spice_disc
                                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                09-08-2024, 02:37 PM
                              • Chrissygizmo
                                by Chrissygizmo
                                02-10-2025, 12:33 AM
                              • Chrissygizmo
                                samsung galaxy ao2s very temperamental after screen replaced
                                by Chrissygizmo
                                Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                Ive eventually managed to get it on and working but it's very temperamental...
                                The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                05-26-2024, 12:05 AM
                              • KYBOSH
                                Trying to Save - Samsung UN55JS6500 - A line down the screen + Falling LED diffusers
                                by KYBOSH
                                Picked this one up today.
                                In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
                                From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
                                Wanted to get a 2nd opinion from you guys before I gave up the ghost.
                                Great looking TV otherwise.
                                Is there any tricks I can do to try to save this one?
                                If so, i'll gladly order a set of backlights and save this one from the landfill..
                                Thanks in advance
                                10-04-2024, 11:00 PM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
